Absorption Of γ - Radiation in Lead/Absorption coefficient
1 reply · 2K views
Hypro96
EXPERIMENT ABSORPTION OF γ - RADIATION IN LEAD AND CALCULATION OF ABSORPTION COEFFICIENT µ
Using equation (3) / slope of graph lnC vs d - estimate µ. This should be in units of per meter (m-1 ).
The formula in the analysis are as follows :
1. I = I0 e-μd
2. C(d) = C0 e-μd​
3. lnC = lnC0 -μd
You may ignore the decimal point at the RANGE=10 setting on the scaler/timer ! so the count then turns out to be whole numbers .
Data (where d is the thickness of the lead sheets):
  • d(m) = 0.0121 ,0.0063 ,0.0025 ,0.0184 ,0.0146 ,0.008
  • Count/min = 636 ,1050 ,1474 ,424 ,454 ,700
  • C (counts/min) - background count = 28
  • Find ln C
For the graph i subbed in the values of C to lnC and plotted it vs d(m) ,the result i got as for the line eq. was
y = -0.0116x +0.0886 in excell with the tread line . I hope the axis were right :P .
So μ≈ -0.0116
Using the equation was hard for me as I'm not sure which component is which , i feel like what I am doing is awfully wrong. I tried to work out μ by subbing in values from the table to C(d) and C0 equation 2 i did the same for the 3 equation and tried to solve with rules of logs , taking C0 as background count of 28 .
I would appreciate any explanation so i can do the calculation and see what happens .
So =
d (m) = 0.0025, 0.0063 , 0.0089 , 0.0121 , 0.0146 ,0.0184
count/min= 1.474, 1.050 , 0.700 , 0.636, 0.454, 0.424
C (counts/min) - backgnd count = 1.446 , 1.022 , 0.672 ,0.608 , 0.426 , 0.396 ( that is subtracting 0.028 from the counts )
ln C = 0.3688 , 0.02176 ,-0.3975 ,-0.4976 ,-0.8533 ,-0.9263 ( that is subbing in C backgnd for C )
graph yields : y = -0.0109x + 0.0065 hence μ = -0.0109
i tired to solve the c(d) in equation 2 with the info we have + the mu from graph .
I thought it should give me back the value from before we subtracted the backend (C counts/min) but i didnt so i swapped around the values and changed the mu and its like we never get back any value but get a new one that's close to what we sub in for C0
basically when i tried to solve μ from equation 3 eg. (ln1.474 / 0.3688) / 0.0025 = 420.8 m-1 which is wrong
