Abstract Algebra: a problem about ideal
iwonde
Let J be the set of all polynomials with zero constant term in Z[x]. (Z=integers)
a.) Show that J is the principal ideal (x) in Z[x].
b.) Show that Z[x]/J consists of an infinite number of distinct cosets, one for each n\inZ.
I have trouble understanding what a principal ideal is. Any help on how I should start would be great. Thanks!
Well, what's the set generated by {x} in Z(x)? Isn't it just x*Z(x)? What's that?
An ideal is a subset of a ring that's closed under addition of its own elements and under multiplication by anything in the ring. A principal ideal is one that's generated by one element.
So, take an element in Z[x] and multiply it by x. Whatever you get, by definition, is in the ideal (x). What do those things look like?
Now, two things are in the same coset of Z[x]/J if their difference is in J. So, if I can subtract off any polynomial I want with zero constant term, what stays unchanged?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
