Abstract algebra question chapter 1.2
blairebear
prove that if 2 does not divide a then 24 divides a^2-1
I know that if 2 does not divide a then a is odd.
I proved that the square for all odd integers are of the form 8K+1
I also proved the square of any integer is either in the form 3k, 3k+1 or 3k+2. I know 3k and 3k+2 are even so the odd are in the form 3k+1
Can I simply say that because both 8 and 3 are in this form then 8*3 is in this form?
That is not what I mean to say. based on before I know that 8 divides a^2-1 and 3 divides a^2-1. Can I then say that since both 3 and 8 divide a^2-1 then 24 divides a^2-1
Ok, I just realized that 3k and 3k+2 are not necessarily even and 3k+1 is not necessarily odd. So now I am even more confused
OK, I am going to say this is not true. When a=3 then a^2 is in the form 3k. so I have disproved it I think.
However the next part says if 2 or 3 do not divide a. That eliminates every third number. I also read my proof wrong and it is either 3k or 3k+1 not 3k+2 so eliminating all the times when 3 divides a will leave me the other two options and for each of those a^2 is in the form 3k+1. OK, I need to write it up but I think I got it.
If this hypothesis is true, then this conclusion is true, by the Chinese Remainder Theorem.
Or, since 3 and 8 have no prime factors in common, yes, any number that is divisible by both 3 and 8 is divisible by 3(8)= 24.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
