AC circuit and non-conservative field
11 replies · 2K views · last reply
kidsasd987
TL;DR
AC circuit generator generates EMF which is due to time-varying magnetic flux.
Then EMF is generated because there is a non-conservative electric field within a circuit.
However, R is defined with respect to the conservative field, where we know v=iR generally holds for an AC circuit. How can we use R derived from an assumption that E=-del V if an AC source generates a non-conservative field within a closed-loop?
Clearly, a non-conservative field can't be del of a scalar function.
*Please refer to the attached question file
A non-conservative EMF violates the assumptions of circuit theory, so you cannot use the circuit theory form of Ohm’s law.
Since this becomes a problem in Maxwell’s equations you need to use the compatible form of Ohm’s law: ##\vec J = \sigma \vec E##
I am not going to open a word document.
Ohm's Law is of course valid also for "non-conservative" fields. It's just a transport property of a conducting medium. The constitutive relation in non-relativistic approximation is
$$\vec{j}=\sigma \vec{E}.$$
Since ##\vec{E}## is not conservative there is no electric potential but that doesn't invalidate Ohm's law for a resistor. Just integrate Faraday's Law
$$\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}$$
along the circuit, consisting of your generated and the resistance gives you
$$\mathcal{E}=R i,$$
where ##R=l/(A \sigma)## is the resistance. Note that
$$\mathcal{E}=\oint \mathrm{d} \vec{x} \cdot \vec{E}$$
is NOT a voltage!
Thanks a lot!
is NOT a voltage!
Thanks!
so as far as I understand,
1. so emf is not a voltage because the voltage is defined with respect to conservative electric fields and emf is defined with respect to a non-conservative field.
2. and ohm's law holds because J=σE is just a transport property of a conducting medium (Drude model). so E can be non-conservative. in the word doc, I assumed E = -Del V and found R but for the more general case including the non-conservative field, I should define R from J=σE.
Is this right?
but I have one more question tho.. Is it ok to use R that I found from a conservative field in the word doc?
I assume I can do that because J=σE is dependent on the material property of the conductor and geometry. So once I found R with respect to a conservative field, it should not change when the non-conservative fields are applied. (The generalized resistance equation for R is defined with respect to voltage, not EMF)
This is where I got confused. R is the same for conservative fields and non-conservative fields? It sort of makes sense because it's a material property, but I am not 100% sure.
Consider a generator with zero resistance as in your word figure of sect. 2: there can be no net E field in the generator wire yet we know from Maxwell that a non-conservative E field is generated - again as you say.
In the wire, in order to reconcile this paradox, an equal and opposite E field is generated in the generator wire which is conservative, yielding net zero E field. Further, since the circulation of a conservative field has to be zero it follows immediately that the E field in the external resistor R is 100% conservative and equal but opposite to the conservative E field in the generator..
Call the non-conservative field ## \bf E_m ## and the conservative field ## \bf E_s ##. The total E field is just ## \bf E_m + \bf E_s ## vectorially, everywhere around the circuit.
The relations are then
## emf = \int \bf E_m \cdot \bf dl ## (integration thru all the wire);
since ## \oint \bf E_s \cdot \bf dl = 0 ## it also follows that
## \oint \bf E \cdot \bf dl = emf ## numerically. Again, as you state.
Whereas
voltage V = ## \int \bf E_s \cdot \bf dl ##. Circulation of this integral follows Kirchhoff's voltage law ## \Sigma \Delta V = 0 ##.
If there is resistance in the generator wire then the ## E_s ## field is reduced by the amount ## iR_{int} ## where i = current.
## \oint \bf E_s \cdot \bf dl = 0 ## still of course. Current i is consequently reduced by the internal wire resistance to ## emf/(R + R_{int}). ##. emf is unaffected.
I recommend my blog https://www.physicsforums.com/threads/how-to-recognize-split-electric-fields-comments.984872/
for further study.
  • Skeptical
It has been clearly shown that your concept is mathematically invalid. Your idea is full of mathematical self-contradictions that were clearly pointed out in your insights conversation. I would not recommend it to students (or anyone) learning this material.
I have let you have your say by not deleting it, but that doesn’t mean that I should be quiet and let a student be confused
Fortunately math is right or wrong and not a matter of opinion! I couldn't agree more with @Dale !
