AC Magnetic Field (solenoid) ID OD L AmpTurns Relationship
The discussion focuses on creating a 0.4 Tesla AC magnetic coil using a solenoid with specific dimensions: ID 38mm, OD 155mm, and a length of 50mm, utilizing 3.5mm x 1.5mm wire with 380 turns. The user achieves 0.27 Tesla at 75 Amps but experiences overheating issues after 5 minutes of operation. Key insights include the direct proportionality of the magnetic field to Amp Turns and the importance of wire thickness for heat management. Recommendations include adjusting coil dimensions and considering parallel windings to enhance performance while ensuring safety due to the high energy involved.
  • Understanding of solenoid design principles
  • Familiarity with AC magnetic field calculations
  • Knowledge of wire gauge and its impact on resistance and heat
  • Basic electrical safety practices when working with high currents
  • Research the relationship between solenoid dimensions and magnetic field strength
  • Learn about wire gauge selection for high-current applications
  • Explore parallel winding techniques for solenoids
  • Study safety protocols for handling high-energy electrical systems
Electrical engineers, hobbyists designing magnetic coils, and anyone involved in high-current AC applications seeking to optimize solenoid performance and safety.
gosain_sanjay
I am trying to make a .4 Tesla AC (50Hz) magnetic coil. Originally I used ID-38MM, OD-155MM & Length of Solenoid 50MM. Using 3.5MM X 1.5MM wire 380 Turns. I get 0.27 Tesla at 75Amp. but the wire allows me to work only for around 5 Min with Forced air cooling.
I do not know the relationship how the field will depend on ID,OD & Length (just that the field is directly proportional to Amp Turns).
It would be great if some could give a conditions for maximum field.
Any guidance will be great help since i was not able to find anything on NET.
If no one has an answer can anyone suggest a Book for Ac coils ?
Hi gosain_sanjay! There are a number of inter-related factors to play with. Is 75A the maximum current you are able to supply? In which case, you can only change coil dimensions and number of turns to gain a stronger field. If your arrangement gets too hot, then you will have to use thicker wire or else use two parallel windings.
If you double the wire's cross-sectional area, you halve its resistance and the amount of heat produced falls by half, providing current remains the same. However, with the bulkier windings, there is probably less effective cooling so the temperature may not fall by as much as you would hope.
With such a large current in a large inductance, there is considerable energy stored and this can be hazardous. If a wire should break or a connection come apart, this energy will be released in one giant flash splattering molten copper around. Tight-fitting safety glasses are a must.
  • · Replies 27 ·
  • · Replies 20 ·
10K
