Accelation problem, how do I change units (km/h to m/s)?
  • Thread starter Thread starter pillar
    Change Units
To convert acceleration from km/h to m/s², first convert the speed from km/h to m/s using the conversion factors: 1 km = 1000 m and 1 hour = 3600 seconds. The acceleration of ThrustSSC, which reaches 1000 km/h in 16 seconds, can be calculated by first determining the speed in m/s, then using the formula for acceleration as the change in velocity divided by time. The correct unit for acceleration is m/s², achieved by dividing the velocity in m/s by the time in seconds. Following these steps ensures accurate conversion and calculation of acceleration.
pillar
I made a mistake I meant km/h to m/s^2.
1. ThrustSSC, the world's first supersonic car, accelerates from rest to 1000km/h in 16 s. What is its acceleration in m/s?
2.a=v/t = v-v0/t-0
3. I'm not sure how to change units (Professor didn't show me.), so can you please now all the work to the problem? Thanks in advance.
Use dimensional analysis, first you should convert the speed from km/h to m/s. Whats the conversion between kilometers and meters? And hours to seconds? The first is easy, 1000m = 1km. The second is 1h = 3600s. Simply multiply the speed by the correct conversion factors to get your result.
Wait I'm sorry I meant km/h m/s2.
Do as Pengwuino says: First convert km/h to m/s.
Hint: 1 km = how many meters? 1 hr = how many seconds? Substitute!
1 km=1000m 1 hr = 3600s I'm not sure how to convert it to m/s^2 Unless I'm suppose to square the 3600, right?
So this guy accelerated by 1000km/h in 16 s. That's 62.5 km/h every second. What's 62.5 km/h in m/s?
You don't want to divide by the time it took him to reach that speed in the first step. If you did, you'd have something with units km/(h*s) which isn't what you want. Put your answer into m/s and then you can divide by the time in seconds which will result in a m/s^2 answer. Fill in the blanks here:
\[<br /> \frac{m}{s} = \frac{{km}}{h}*\frac{{1h}}{{?s}}*\frac{{?m}}{{1km}}<br /> \]<br /> <br />
I understand now velocity is m/s, plugging it into a formula (say acceleration = change in velocity/time) time=s velocity= m * s^-1 m * s^-1 * s^-1=m/s^-2=m/s^2
Thanks all.
