Acceleration and Distance problem
  • Thread starter Thread starter The Tutor
    Acceleration
A turtle accelerates along a straight ditch, taking 10 seconds to travel 10 meters to a pine tree, reaching a speed of 1.2 m/s. The acceleration calculated is 0.04 m/s². To find the distance from the fence post where the turtle started from rest, the first equation of motion can be applied using the initial velocity of 0 m/s and the final velocity of 0.8 m/s. This approach leads to the solution for the distance traveled from the fence post. The discussion emphasizes the importance of correctly applying the equations of motion to solve the problem.
The Tutor
A turtle is moving with constant acceleration along a straight ditch. He starts his stopwatch as he passes a fence post and notes that it takes him 10s to reach a pine tree 10m further along the ditch. As he passes the pine tree, his speed is 1.2m/s. How far was he from the fence post when he started from rest?
V22=V12+2a\Deltad
\Deltad=V1\Deltat+1/2a(\Deltat)2
\Deltad=V2\Deltat-1/2a(\Deltat)2
So I found out acceleration using the third equation, which is .04 m/s2. So now I believe I have to figure out the velocity at the fence post, which comes to 0.8 m/s. I don't know what to do after that.
You've already done all the work. All they are asking you is to solve for the distance the turtle traveled from rest to the fence post. Just use equation 1 with V1 = 0, V2 = 0.8 m/s, and a = .04 m/s^2.
Oh. Yeah I see that now thanks.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
