Acceleration and friction force problem
The problem involves a 20-ton bus accelerating to 10 m/s over 50 meters with a pushing force of 14,000 N. Calculating the acceleration yields 1 m/s², leading to a total force equation that suggests a friction force of -4,000 N, which is illogical. Discussions highlight that the friction force should equal the pushing force for the bus to accelerate, contradicting the given parameters. Alternative perspectives suggest potential errors in the problem's formulation or assumptions about the bus's conditions, such as wind assistance. Overall, the scenario presents inconsistencies that challenge the validity of the problem.
AlexPilk
Mass of the bus is 20 tons. It accelerates to 10 m/s (from initial speed of 0) in 50 meters. Find the coefficient of friction (u) if the force, that pushes the bus = 14*10^3 N
m=20t=20000kg
S=50m
v=10m/s
F=14kN=14000N
So we can find out what the acceleration is using
a=2S/v^2
And it will be equal to 1 m/s^2
But, the total force F(total)=F-F(friction)=m*a=14000-F(friction)=20000
So it turns out Force of friction = -4kN. How can this be, what did I do wrong?
I agree with you. It doesn't seem to make sense.
Chet
I also agree. Another way of looking at it would be to look at work done by the pushing force which would equal 700 kJ. The kinetic energy of the bus moving at 10 m/s would be 1 MJ so the same problem manifests itself in that consideration too.
So we can find out what the acceleration is using a=2S/v^2
The SUVAT equation is..
V^2 = U^2 +2as
U=0
so
a = V^2/2s
but despite that you still get a=1m/s^2
I thought perhaps they meant imperial (US short) Tons rather than metric but that's about 18,100kg and you still get a negative answer.
A strong tail wind is the only thing I can think of.
The friction with the ground is actually what pushes the bus so if the "force that pushes the bus is 14,000N" then the friction force with the ground must also 14,000N. But in that case the bus won't accelerate as fast as stated. I agree it makes no sense.
It's not unknown for teachers/examiners to copy old questions and change the values without checking it all hangs together.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
