Acceleration down an inclined plane
The discussion focuses on calculating the coefficient of kinetic friction for a 25-kg box sliding down a 9.0-meter incline at a 15° angle, reaching a speed of 2.4 m/s. The user attempts to apply Newton's second law and kinematic equations to find the acceleration and ultimately the friction coefficient. There is uncertainty about whether the acceleration is constant due to friction's influence. A suggestion is made to use energy conservation principles to verify the results by comparing potential energy at the top and kinetic energy at the bottom. The conversation emphasizes the importance of understanding forces and energy transformations in solving the problem.
jakerue
A 25-kg box slides, from rest, down a 9.0-m-long incline that makes an angle of
15° with the horizontal. The speed of the box when it reaches the bottom of the
incline is 2.4 m/s. (a) What is the coefficient of kinetic friction between the box
and the surface of the incline? (b) How much work is done on the box by the
force of friction? (c) What is the change in the potential energy of the box?
Fx = mg * sin15
Fn = mg * cos15
Ffr = uk * Fn = uk * mg * cos15
Vf2-Vo2 = 2 *a*d
Having an issue with kinetic friction calculation here
Taking the force components and applying Newton's 2nd law -> ƩF = ma
Fx - Ffr = max
mg * sin 15 - uk (mg * cos 15) = m * ax
Since I want uk and the final velocity is given, I calculate accel -> Vf2 - Vo2 = 2*a*d so a = 2.4m/s / (2*9.0m) = 0.32 m/s^2
Can I put it into mg * sin 15 - uk (mg * cos 15) = m * ax and end up with uk = 0.2345 ?
I can't get over that ax isn't constant acceleration and I don't think I can use it in this case...
I would assume constant acceleration, since there is no external forces acting on the box and it's sliding under its own mass. Therefore, I believe your method is correct.
What makes you think that the acceleration is not constant? Can you identify a force that changes during the slide?
If you're leery about the acceleration you could always check the result by using an energy conservation approach. You know the potential energy (due to gravity) at the top of the slope, and the kinetic energy at the bottom (i.e. velocity). The difference of the two will be the energy lost to friction.
