What is the proper way to calculate time squared in seconds?
To calculate time squared in seconds from milliseconds, it is essential to square both the numerical value and the units. When squaring 150 milliseconds directly, the result is 22,500 milliseconds squared (ms²), which requires conversion to seconds squared (s²) by multiplying by 10^-6. Alternatively, converting 150 milliseconds to 0.150 seconds before squaring yields 0.0225 seconds squared (s²). The preferred method is to convert to standard units first for clarity in calculations. Proper unit conversion is crucial to ensure accurate results in time squared calculations.
jendrix
Hello, I'm currently doing some work on the above and have ran into a problem when calculating the Time squared part as it should be in Seconds squared.
I currently have the time in miliseconds, so say I have
150ms should I square this number then convert it into seconds or convert it first and then square it.
For example 150ms the first way gives 22500 which is 22.5s
Converting it to 0.150s then squaring it gives 0.0225?
Thanks
(150ms)2 = (0.150s)2 = (0.150)2(s)2 = 0.0225 s2
Or:
(150ms)2 = (150)2(ms)2 = (150)2(0.001 s)2 = 0.0225 s2
Key point:
1 (ms)2 = 10-6 s2
I appreciate your help but I'm still puzzled by this.
What part puzzles you?
I'll try again:
Whatever you do, you must square both the number and the units.
No. When you square 150 ms you end up with 22500 ms2 (not just ms). You'd have to convert from ms2 to s2, which means multiplying by 10-6.
That's fine. Notice that your units are s2.
Personally, I would always convert to standard units before doing any calculations. So I would convert 150 ms to 0.150 s, and then I'd do my squaring.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
