Acceleration of 2 boxes sliding down ramp - please
In summary, the conversation is discussing a physics problem involving two boxes on an inclined plane. The question is to determine the acceleration of the system and explain the method used, as well as identify any applicable laws. The conversation covers the use of Newton's 2nd and 3rd laws, the importance of drawing accurate free body diagrams, and the concept of solving for the acceleration of one box and applying it to the entire system. The final answer is 18 N.
nukeman
655
Please refer to the diagram. I have having trouble with B: "Determine the acceleration of the system. Explain your method, and identify and laws you are applying"
Ok so for A:, I drew two FBD's. For package A there is Fg, Fnormal, Ffriction, and F from box B - Correct?
Box B - Fg, Fnormal, Ffriction, and FfromboxA - Correct?
So now B is where I am having trouble. I am not sure how to find the acceleration of the SYSTEM ?
OK. (Hopefully you drew the directions correctly.)
Newton's 2nd law. (Analyze force components parallel and perpendicular to the incline.)
Well, box A in front has a higher coefficient of friction, and so it will always be moving slower than box B. So the motion of box B is affected by the motion of box A, and vice versa (i.e. box B is pushing on box A because box A won't get out of its way).
So the motion of the system is really determined by the motion of box A or B, since they move together. When you draw the FBD of box A, first assume that box B isn't there, and include all relevant forces, then add in the force box B exerts on A, and that should describe the motion of the system.
Ok I see what you are saying.
I am just having trouble figuring out the acceleration. What method do I use to figure this out?
The acceleration of either box A or B is the acceleration of the system - they are both moving with the same acceleration.
Yes I get that... since they are moving together, they have the same acceleration.
BUT - how do I figure out the actual acceleration?
You need to write your equations of motion for each box. After doing this what do you have in the inclined direction? Remember Newton's third law...
so my first step would be to choose a cordinate system, and then delevope an equation?
Yep. This is the case for tackling almost any problem. So what do you get?
Give me a sec... We just started doing these (FBD's to equations) and IM not 100% comfortable yet doing them.
Ill post it in a sec here.
Ok drew it out, with coordinate system, and a table. Not sure if this is correct. Can yuou look over my table?
Draw them out as separate and draw Free body diagrams then equations for each block. Your table looks ok for the entire system but you should label 'Fgravity' as 'Fparallel' or something like that indicating that it acts parallel to the ramp. The value of 'Fgravity' is just 'mg' and it acts vertical. On the other hand 'Fparallel' and 'Fperpendicuarl' are the components of 'Fgravity' in the x and y directions.
By the way you can solve for the acceleration of the blocks by solving it as a system vs writing equations for each block. But then you will still have to write and equation for one of the blocks to find the force 'F' that acts between them...
So, if I go the system route, is my table correct?
To add to my table the ma of x would be what? and what would the ma of y be?
Can anyone confirm my table is correct?
what is the ma of x and the ma of y
Still don't know how to find those :(
Thanks so much guys!
How are you able to find the frictional force on the system?
Its just the sum of the friction forces for both blocks. I was not 100% sure how the system approach would work but it seems that if you do it as a system it is the same as if you wrote an equation for each block and added them together canceling out the interaction force 'F' between them.
Now for C
Now package A and package B are sliding down a ramp together, so they have the exact same acceleration. The acceleration of the system is 1.8 m/s^2 and the mass of package B is 10kg
So, is it simply F = ma
F = (10kg)(1.8) = 18 N ?
FAQ: Acceleration of 2 boxes sliding down ramp - please
1. What is acceleration?
Acceleration is the rate at which an object's velocity changes over time. It is calculated by dividing the change in velocity by the change in time.
2. How is acceleration related to force?
According to Newton's second law of motion, force is equal to an object's mass multiplied by its acceleration. This means that the more force applied to an object, the greater its acceleration will be.
3. How does the angle of a ramp affect the acceleration of objects sliding down it?
The angle of a ramp can affect the acceleration of objects sliding down it. Generally, a steeper ramp will result in a greater acceleration due to the force of gravity acting more directly on the object.
4. What role does friction play in the acceleration of objects down a ramp?
Friction can act to slow down the acceleration of objects sliding down a ramp. If there is a lot of friction between the ramp and the objects, it will take more force to overcome this resistance and accelerate the objects.
5. Can the mass of an object affect its acceleration down a ramp?
Yes, the mass of an object can affect its acceleration down a ramp. Heavier objects will require more force to accelerate and will therefore have a slower acceleration compared to lighter objects.
