Acceleration of a metal piece due to dipole radiation magnetic field
The discussion centers on the effects of dipole radiation magnetic fields on metal objects, specifically regarding the acceleration of a metal piece placed within such a field. The calculations presented involve determining the induced electromotive force (emf) and resulting eddy currents in a thin round metal disk, leading to a derived total magnetic moment. It is confirmed that a metal object in an alternating magnetic field will experience a force due to the induced eddy currents, which act in opposition to the changing magnetic field, in accordance with Lenz's principle. The force experienced by the metal is influenced by the parameters of the magnetic field and the geometry of the object. Overall, the findings suggest that the metal will indeed accelerate in response to the dipole radiation magnetic field.
Wayne Lai
Recently I am learning about electrodynamic radiation and its various types, and it occur to me that since the form of the magnetic field created by the dipole radiation is some combination of cos(wt), 1/r, and cos(kr) (take the approximation of r >> c/w)
Therefore, if there is a metal placed in the field, will it be accelerate by the field?
I've done some simple calculations on the case of a thin round metal disk, which the normal vector of its surface is parallel to the tangent line of magnetic field.
By calculate the emf that create by the changing magnetic field value (regarding the time changing and the displacement), I obtain the eddy current for each radius.
By integrating these factors, I get the the total magnetic moment M, thus by using the rule F=-dU/dr and U=M*B, I find the force will be proportional to the sum of v/r^3 and (v/r)*k^2 (which I take the average of time and position on the (cos^2)s).
Could anyone tell me whether this result is correct or not, please?
Hi
I didn't follow your calculations, but the answer to your question is YES. If you place a metal object in a alternating magnetic field, the eddy current induced will produce a force on that metal object and the force will be directed away from the alternating magnetic field source. This is a consequence of the Lenz principle: eddy currents induced oppose the change of the magnetic field.
With a strong enough magnetic field, the effects can be quite dramatic. Have a look at this video
