Acceleration of mass on a spring
To determine the acceleration of a 2.0 kg mass on a compressed spring, start by using Hooke's Law, F = -kx, where k is the spring constant. Even without a numerical value for k, you can express the force in terms of k by considering the gravitational force acting on the mass, F = mg. By substituting k with mg/x, where x is the compression distance, you can find the force exerted by the spring. Finally, apply Newton's second law, F = ma, to solve for the acceleration of the mass after the spring is released. This approach allows you to derive the acceleration in terms of the spring constant and the compression distance.
futurept
A 2.0 kg mass is placed on top of a vertical spring, which compresses to a new equilibrium position; the spring is then compressed from this new equilibrium position by a distance of 0.05 m. What will be the acceleration of the mass just after the spring is released from this position?
I don't really know where to start. The only equation I can find that is relevant is F= -kx. But no spring constant is given. Any help please?
All I'm really asking for here is the starting point. I think I can do it from there, I just don't know where to get started from.
It doesn't matter if they don't give you a numerical value for k. It means your answer will depends of k.
So what do I do then. Consider that k=mg/x? then from there I can find the force. Then set that value to F=ma?
