Acceleration of mass with friction
The discussion revolves around calculating the acceleration of a block moving up a slope under the influence of various forces, including friction. The user initially attempted to analyze the forces acting on the block but struggled with the correct application of the equations, particularly regarding the role of tension in the pulley and the direction of friction. Participants emphasized the importance of considering all forces, including the tension in the rope and the effects of friction, which opposes the block's motion. Clarifications were provided on how to approach the problem symbolically before substituting numerical values. The conversation highlights the need for careful analysis of forces and the correct interpretation of the problem's parameters.
Jonski
At the instant shown the block is moving down the slope with P= 49 N, β= 38°, θ= 33° and M= 33 kg.
What is the acceleration of the block up the slope if the kinetic coefficient of friction is 0.5?
So I split all the forces into the normal direction and parallel to the plane
Forces in the normal = 0 = N - mgcos33 + 49sin38
N = 241.34
Forces parallel to the plane = 49cos38 - mgsin33 + 0.5N
= -17.036
F/m = a
a = -17.036/33 = -0.516
But I am not getting the right answer, please help
Draw the FBD for mass M.
Now what, I added up all the forces in each direction. Not sure where I went wrong
Oh, my earlier post didn't load.
First of, does friction oppose or support the motion of the block ?
And second, is the force on M being exerted by P, or the pulley ?
Hope this helps.
We are told that acceleration is up the slope but the present velocity is down.
haruspex said:
You are missing a force. Consider the forces acting on the pulley.
I think the force I am missing is tension in the pulley,
Not sure but is it mgsin(theta)
Not sure what you mean by tension "in" the pulley. The rope runs around the pulley. It will be more convenient to think of it as two separate ropes, but you need know the tension in each (which will be?)
Would it be p + mgsin(theta)
What is the tension in the upper part of the rope?
Is it 49N ?
Oops ! Missed the down.
so P + mgsin(theta) + mgcos(theta)*friction
Sorry my bad..
Jonski said:
Is it 49N ?
Yes, it's P, which is given as 49N.
It doesn't say, but you should take the pulley as massless and having no axle friction. If the tension in the upper part of the rope is P, what must it be in the lower part? Hint: think about the net torque on the pulley.
n_freitass said:
Would your force parallel be ##F_p : \mu_kN + P + Pcos(\beta) - mg sin(\theta) = ma_p## ?
And force normal be ##F_n : Psin(\beta)+N-mgcos(\theta) = 0 ##
Please do not provide answers. The system on the homework forums is that we provide hints, explain misconceptions, point out algebraic errrors, etc.
