Accurate estimation of complex eigenvalues
soikez
Hello,
I use Arnoldi iterative algorithm in order to compute the eigenvalues of a matrix. I know that the eigenvalues are of the form \lambda(1+j/c) and I can totally estimate them. The problem that occurs is that both the range of \lambda_0 and c is for example [100,1000]. That means that there is a significant difference in the order of real and imaginary part e.g. (10^4,10^6), so the algorithm I use defines with more accuracy the real part of the eigenvalue. To be more specific let me give an example. If I estimate an eigenvalue, using python or matlab, as \lambda=100+0.017j, the analytically computed eigenvalue is \lambda=100.1+0.012j. This deviation in the imaginary part causes a lot of problems.
Is there any way of normalization in order to exceed this problem of accuracy?
Thanks in advance!
You could try to describe it as a purely real problem by using the vector space isomorphism ##\mathbb{C}\cong \mathbb{R}\oplus \mathbb{R}##.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
