Why is H3O+ the Strongest Acid & OH- the Strongest Base?
  • Thread starter Thread starter bomba923
H3O+ is considered the strongest acid in aqueous solutions because it results from the protonation of water molecules when a stronger acid donates protons. This process generates hydronium ions, which dominate in acidic environments. Conversely, OH- is the strongest base present in significant amounts in water, as strong bases extract protons from water, leading to an increase in hydroxide ions. The presence of excess water in these solutions facilitates the formation of H3O+ and OH-, establishing their roles as the strongest acid and base, respectively.
bomba923
Why is H3O+ the strongest acid and OH- the strongest base that can exist in significant amounts in aqueous solutions?
Chemistry news on Phys.org
Because usually in aqueous solutions you have excess of water. If you add some stronger acid it donates its proton(s) to the water particles. Similar reasoning holds for strong bases - they will steal protons from water leaving OH- in the solution.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
