Order of acidity for oxoacids of P: H3PO4 > H3PO3 > H3PO2
  • Thread starter Thread starter zorro
The discussion centers on the order of acidity for the oxoacids of phosphorus: H3PO4, H3PO3, and H3PO2. It is established that H3PO4 is the most acidic due to its higher basicity and greater number of replaceable H+ ions. However, a participant notes that the acidity order contradicts their initial assumption when checking Ka values, which indicate a different order. The conversation highlights the importance of understanding the electron-withdrawing effects of oxygen in determining acidity. Ultimately, the need for theoretical reasoning is emphasized, as exam conditions may not provide Ka values.
zorro
What is the order of acidity of H3PO3, H3PO2 and H3PO4?
H3PO4 must be most acidic because its basicity is highest. Greater the no. of repleacable H+, greater will be its acidity. On similar reasoning, H3PO2 is least acidic.
Is it right?
There is a rule about acid strength and amount of oxygen in the molecule.
I guess you are talking about the withdrawing effect of Oxygens.
There is only one Oxygen doubly bonded to Phosphorus which withdraws electron density of the O-H group facilitating the release of H+. Since there is only one such O in every molecule given, I don't think we can compare based on that rule. Correct me if I am wrong.
Good point, my mistake.
Safest approach it to check tables for Ka values.
I googled their Ka values and to my surprise, found that the acidity order is opposite to that I mentioned in O.P.
Unfortunately these values are not given in my exam and I need an answer theoretically ( I am not so good at by-hearting things :biggrin:)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
