Action Var: 1 DOF System, Ellipse Path in Phase-Space
  • Thread starter quasar987
  • Tags
    Variables
In summary, the action variable J for a 1 degree of freedom system is defined as the integral of p(q) over a period. In the case of an harmonic oscillator with an elliptical path in phase-space, the period can be parametrized in the standard way and integrated over one period. This approach was suggested by GJ and could have been used in an exam.
quasar987
32
Suppose a 1 degree of freedom system. Then, the action variable J is defined by
[tex]J\equiv\oint p(q)dq[/tex]
where the integral is taken over a period of p(q). What shall this period be in the case of say, an harmonic oscillator, where the path in phase-space is an ellipse and hence p(q) is not even single-valued?
Parametrize the ellipse in the standard way, and integrate over one period.
Dang it. This is what I tought about doing in my exam too but I had no more time when the idea finally hit me. Thanks GJ.
Related to Action Var: 1 DOF System, Ellipse Path in Phase-Space
1. What is a 1 DOF system?
A 1 DOF (degree of freedom) system refers to a physical system that has only one independent variable or coordinate that describes its motion. This means that the motion of the system can be completely determined by a single parameter, such as position or angle.
2. What is an ellipse path in phase-space?
In a 1 DOF system, the phase-space plot is a graph that shows the behavior of the system over time, with the position of the system plotted against its momentum or velocity. An ellipse path in phase-space refers to the shape of the plot when the system undergoes simple harmonic motion. The center of the ellipse represents the equilibrium position of the system, and the shape of the ellipse depends on the amplitude and frequency of the motion.
3. How is an ellipse path in phase-space related to energy conservation?
In a 1 DOF system, the total energy of the system is conserved. This means that the sum of kinetic and potential energy remains constant throughout the motion. The shape of the ellipse path in phase-space is determined by the total energy of the system, with higher energy states resulting in larger ellipses.
4. What is the significance of studying an action variable in a 1 DOF system?
An action variable is a measure of the average energy transfer per cycle of the system. It is a useful tool for analyzing the dynamics of a 1 DOF system because it provides a simplified representation of the system's behavior. By studying the action variable, we can gain insights into the stability, periodicity, and energy of the system.
5. How does the shape of the ellipse path change with different initial conditions in a 1 DOF system?
The shape of the ellipse path in phase-space is determined by the initial conditions of the system, such as the amplitude and phase of the motion. Changing these initial conditions can result in different sized and shaped ellipses, representing different energy states and behaviors of the system. For example, a larger amplitude will result in a larger ellipse, while a different phase will result in a rotated ellipse.
  • Classical Physics
