Calculating Activation Energy and Rate Constant for a Chemical Reaction
  • Thread starter Thread starter kittymaniac84
    Activation Energy
The discussion focuses on calculating the activation energy and rate constant for the reaction 2NOCI (g) = 2NO (g) + Cl2 (g) using the Arrhenius equation. The provided rate constants at two temperatures (350 K and 400 K) allow for the determination of the activation energy (Ea) and the pre-exponential factor (A). One participant initially expressed confusion about applying the Arrhenius equation but later confirmed their calculations. The final results indicated an activation energy of 100,232 J/mol and a rate constant of 4.06 x 10^-3 Is at 425 K. The calculations appear to be verified and correct.
kittymaniac84
[SOLVED] Activation energy
The reaction, 2NOCI (g) = 2NO (g) + Cl^{}_2{}(g) , has rate constant values for the reaction of NOCl of 9.3 x 10^-6 Is at 350 K and 6.9 x 10^-4 Is at 400 K. Calculate the activation energy for the reaction. What is the rate constant at 425 K?
I am unsure how to solve this. Can someone help me and show me how to do it.
SCREAMS arrhenius equation.
Excuse me, why the rude behavior? This is suppose to be a help forum. It might be obvious to you, but I'm not sure if I am using the equation right.
The Arrhenius equation is ln(k) = ln(A) - E/(RT). You are given values of k at two different temperatures T. R is the gas constant, A and E are empirical constants, E being the activation energy. So just plug the corresponding values (k,T) into this equation to generate two equations in two unknowns. After you know A and E, use the equation to get k at any other T. Does this help?
Yes thank you. I already figured this out on my own. That is exactly what I did. Ea=100,232, A=8.47x10^9, and with T=425 I got 4.06x10^-3 for k.
I hope i did the math right but it looks right.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
