Add/Sub. Vectors A & B: Find Cx & Cy
  • Thread starter Thread starter littlesohi
    Vectors
Vector A has a magnitude of 12 and an angle of 27 degrees with the x-axis, while vector B has a magnitude of 22 and an angle of 72 degrees. To find the components of vector C for both addition (C = A + B) and subtraction (C = A - B), the components are calculated using the formulas Cx = VxA + VxB and Cy = VyA + VyB. The discussion emphasizes using acute angles directly for calculations, but cautions about interpreting angles correctly when they are given in a different format. The law of sines and cosines can be used, but the preference is for component-based solutions. Properly applying these methods will yield the correct components for vector C.
littlesohi
Vector A has a magnitude of 12 (in some unspecified unit) and makes an angle of 27 with the x-axis, and a vector B has a length of 22 and makes an angle of 72 with the x-axis. Fnd the components of the vector C in the following:
(a) C=A+B
Cx=
Cy=
(b) C=A-B
Cx=
Cy=
you can solve it using the law of sines and the law of cosines, but i prefer solving it with components
Vx=VxA+VxB
Vy=VyA+VyBboth make acute angles to the x-axis, so don't worry, just use those angles, but if you had something like, ''it makes a -30 degree angle with the y-axis'' (meaning it is 330 degrees in the unit circle) you have to use the 330, ALWAYS THE WHOLE WAY AROUND.know you have a big resulting triangle, try to continue yourself in the operations...
