Addition of moments of inertia
The discussion revolves around the addition of moments of inertia, particularly in the context of calculating the moment of inertia for composite shapes, such as spheres and shells. Participants explore whether the principle of adding moments of inertia applies universally to all shapes and if it is governed by a specific theorem.
  • One participant suggests calculating the moment of inertia for a large sphere by adding the moment of inertia of a smaller sphere and that of a spherical shell.
  • Another participant mentions the Parallel Axis Theorem but questions its applicability since the axis of rotation does not change.
  • Some participants assert that "moments of inertia add" and inquire if this principle has a specific name or theorem associated with it.
  • A participant explains the mathematical basis for the addition of moments of inertia using integrals and the definition of moment of inertia.
  • There is a discussion about whether the principle of adding moments of inertia applies to all shapes, provided they are measured relative to a common axis.
  • Several participants reference the principle of superposition as a broader context for understanding the addition of moments of inertia.
  • Some participants express uncertainty about the relationship between the Parallel Axis Theorem and the addition of moments of inertia, suggesting that the theorem primarily addresses shifting axes rather than the addition principle itself.
  • One participant emphasizes the importance of specifying that moments of inertia add only when measured with respect to the same axis.
Participants exhibit a mix of agreement and disagreement regarding the application of the addition principle to moments of inertia. While some support the idea that moments of inertia can be added, others debate the relevance of the Parallel Axis Theorem and the conditions under which the addition holds true.
There are unresolved questions regarding the general applicability of the addition principle to various shapes and the specific conditions required for it to hold, particularly concerning the axes of rotation.
This discussion may be useful for students and professionals interested in mechanics, particularly those dealing with rotational dynamics and the calculation of moments of inertia for composite bodies.
dyn
Hi
To calculate the moment of inertia of a large sphere , I can calculate I for a smaller sphere and then add to it , I for the spherical shell that added to the smaller sphere makes the larger sphere.
Does this general process apply to all shapes ? If so , does this process have a name ie. is it a specific theorem ? If so , what is it called ?
Thanks
Parallel axis theorem.
I don't think it is The Parallel Axis theorem because the axis is not changing. I have heard that "moments of inertia add". This seems to fit the problem I referred to but what exactly does it mean ? Is it a specific theorem ?
<sigh>
Can you draw a picture of what you're asking?
Generally the moment of inertia of a body about an axis is ##\int r^2 dm## where ##r## is the distance to the rotational axis and ##dm## measures the mass of the object. This is equal to ##\iiint_V r^2 \rho(x,y,z) dx dy dz## where ##V## is the region of space the object occupies, ##r## is a function of ##x, y, z## giving the distance to the rotational axis, and ##\rho(x,y,z)## is the mass density at the point ##(x,y,z)##.
If you simply overlay two objects of mass ##m_1## and ##m_2## on top of each other, the integral becomes ##\int r^2 d(m_1 + m_2) = \int r^2 dm_1 + \int r^2 d m_2## or equivalently ##\iiint_V r^2 (\rho_1(x,y,z) + \rho_2(x,y,z)) dx dy dz = \iiint_V r^2 \rho_1(x,y,z) dx dy dz + \iiint_V r^2 \rho_2(x,y,z) dx dy dz## so it is simply the sum of their moments of inertia.
The example is of a large sphere, If I remove a smaller sphere from its centre I am left with the outer hollow shell. To caculate I for the outer shell I can calculate I for the larger and smaller spheres and subtract the smaller from the larger. This seems to apply the principle mentioned in #5 above. Is it just called "moments of inertia add" ? Does it apply to all shapes as long as they are measured relative to a common axis
It's just from the definition of moment of inertia, as noted in #5. If you've got mass in some volume ##V## then the moment of inertia about some axis is ##\int_V\rho r^2dV##, where ##r## is the distance to the axis. But an integral is just the limiting case of a sum. You are perfectly at liberty to do the sum in two stages and write it as ##\int_{V_1}\rho r^2dV+\int_{V_2}\rho r^2dV##, as long as the two volumes ##V_1## and ##V_2## combine to make up the original volume ##V##.
Or you could see it as a consequence of angular momentum conservation. Define the moment of inertia as ##I=L/\omega##, where ##L## is the angular momentum and ##\omega## is the angular velocity. Imagine the two parts of your whole are almost, but not quite, touching and are rotating with the same angular velocity about the same axis. The total angular momentum is ##L=I_1\omega+I_2\omega##. Now the two bodies are connected by a massless thread. The angular momentum can't change due to its conservation. ##\omega## can't change just because of this tiny thread. So the combined moment of inertia needs to be ##I=I_1+I_2##.
That's hardly surprising when you realize that the MI is defined as the Integral of elemental MIs. It will get more complicated when the CMs are not on the same axis but it still works consistently because of the definition.
It's easy to get confused unless you start from the beginning and follow the 'rules'. Trying to impress intuition, initially, on an explanation is doing things in the wrong order. They gave you the Maths as a useful tool and not as something to argue against. :wink:
Please excuse my ignorance; how does the parallel axis theorem apply here? I thought the result follows due to the linearity of the integral operator, allowing the decomposition of ##\iiint_V \rho r^2 dV##, as others have noted.
Look at the derivation (it's a theorem after all) and you can see the recipe for adding new contributing elements no matter where they are.
I still don't follow. All the parallel axis theorem tells me is that I can find the MoI of the same distribution of mass about some other axis if I know the MoI about a parallel axis through the CoM, by means of an additive constant.
Please look at derivations of it. They all show, by example, how to add up the contributing elements, no matter where they are. It seems better to point at existing derivations than to copy it all in a post.
If you understand the theorem, you understand the answer to the OP's question. Of course if you just look at the name and say "This isn't what I want so I won't look at it" you won't get anything out of it.
I am not sure whether I understand a question but if you have a body ##\mathcal B## and its inertia tensor about a point ##A## is ##I## and you have another body ##\mathcal B'## with the inertia tensor about the same point ##I'## then the inertia tensor of ##\mathcal B\cup\mathcal B'## is ##I+I'##
I am quite aware of various different derivations of the PAT, I just don't see how it relates directly to the OP. You have a concentric sphere and shell through which I can position a single axis and subsequently perform the integration (or apply the known results), either together, or by adding the individual results; this choice follows from being able to split the region of integration.
The PAT just transforms the integral for a given distribution of mass, giving you an extra term. This is IMO distinct to asking "why can I then split up the region of integration into two parts, and then add them up again?"
Well, then there is no point in repeating what I said, is there?
It was just out of interest at your first comment, it's always a good idea to try and learn as much as possible from people more knowledgeable, like yourself! In this case I am still not sure I understand what you had in mind, but I'll think on it! :smile:
I would say that the explanation for my OP is "moments of inertia add". See #8. I just think that it's a shame that this principle is not a specific theorem
You could say it comes under the umbrella of the principle of superposition.
$$\int_a^bf(x)+g(x)\ dx = \int_a^bf(x)\ dx + \int_a^bg(x)\ dx$$
As written, it's incomplete since you need to specify the condition you mentioned that the axes have to be the same.
More completely, I think it's better to write
"moments of inertia with respect to the same axes add".​
Without the "with respect to the same axes", it's not correct (although it would be for "mass").
As similar comment would be applied to computing first moments in a center of mass calculation.
... or electric fields due to some configurations of charges.
I would agree with this description. (I use that when I teach.)
This has gone on too long but we are pretty much there. The MI is always relative to a specified axis. It cannot be assumed to be about the CM. So , using the term MI properly, MIs add. It's hardly worth losing sleep or keyboard strokes over this imo.
It is a special case of the parallel axis theorem (when the axes are parallel and also coincident ). It requires no separate discussion.....Really!
  • Skeptical
Now I feel very stupid :-p. I still can't see how the principle of superposition follows from the parallel axis theorem. Here's how I would prove the superposition in this case; we have two overlayed density distributions ##\rho_1(\vec{r})## and ##\rho_2(\vec{r})##. Then $$I_{tot} = \iiint_V (\rho_1(\vec{r}) + \rho_2(\vec{r}))r^2 dV = \iiint_V \rho_1(\vec{r}) r^2 dV + \iiint_V \rho_2(\vec{r})r^2 dV = I_1 + I_2$$
As for the parallel axis theorem, we suppose the vector from the CM to the new axis is ##\vec{r}'##, and that ##\vec{R}## is measured from the CM whilst ##\vec{r}## is measured from the new axis, such that ##\vec{r} = \vec{R} - \vec{r}'##: $$I_p = \iiint_V \rho \vec{r}^2 dV = \iiint_V \rho (\vec{R} - \vec{r}')^2 dV = \iiint_V \rho \vec{R}^2dV -2\vec{r}' \cdot \iiint_V \rho \vec{R} dV + \left( \iiint_V \rho dV \right) \vec{r}'^2 $$ The second term is zero via. the definition of the CM, so we end up with: $$I_p = I_{CM} + md^2$$ where ##|\vec{r}'| = d##. But how does the latter derivation relate to the principle of superposition?
There is no addition of [new] mass associated with the "parallel axis theorem",
unlike the "adding of moments of inertia" by the addition of mass, as described in the OP.
I also cannot see any relation to the Parallel Axis theorem. The principle of superposition or moments of inertia about a common axis add seems to cover my OP
The parallel-axis theorem is about how the moment of inertia changes when the axis of rotation is changed to another axis parallel to it.
What you were asking is the moment of inertia of a body around one fixed axis consisting of different parts. For this situation you simply don't need the parallel-axis theorem.
...except in as far as the total MI of two objects would involve choosing (and stating) a common axis of rotation and shifting the MIs to that common axis. That's only a practical note but pretty important if you happen to know the individual MIs (which will be about their individual CMs).
Right, but for this situation the axis passes through the CM of both objects already :smile:.
In practice my use of the theorem always involves construction of a new object from lesser simpler pieces. If you enjoy a hundred special rules then you are wired different from me.
The construction of any object from two pieces is covered by the parallel axis theorem even if done sequentially in time. And the derivation of the parallel axis theorem must contain the case where the axes of the two objects coincide. I prefer one theorem not three.
  • Skeptical
  • · Replies 49 ·
  • · Replies 30 ·
  • · Replies 138 ·
9K
  • · Replies 30 ·
