sophiecentaur
- 30,085
- 7,377
You seem to be describing what happens in a long wire antenna, in which there is a traveling wave up and down the wire - but, as you are not being specific about the polarisation involved or which direction the currents are flowing in. Why not look at some antenna theory? Wikipedia is a good enough source and much of what you are saying has parallels in standard theory - but not necessarily applied in a 'Kosher' way!
You lose nothing by replacing your "electron sea" by 'currents'. discussing the process in terms of waves and launching into a classical appreciation of the process. If you look at the simplest radiator - a short dipole - fed at the centre there is a boundary condition which says that the current flowing at the end must be zero (it can't be flowing off the end). Yes, you could arrange for a lot of parallel dipoles, very close together, to be fed, in phase, by a set of individual feeders but the presence of the dipoles next to each other is relevant. Waves, launched by one dipole, will reach another nearby dipole and induce currents in it, modifying its effective current. This is due to what we term 'mutual impedance' and gives you an impedance matrix, which describes the relationship between currents and voltages in all the elements in the array. (This. I am sure, is where your last post is effectively taking you). The edge dipoles will be in a different situation from the inner ones and you will arrive at a distribution of 'weighting' across the array.
For an array which is wider than a wavelength, there will be a periodic variation along the width of the array, caused by this mutual impedance. The situation is less of a problem when you are firing broadside because the symmetry of the system tends to balance out the effect but the edge elements will still be affected and you will not have the aperture that you might expect.
The only way to eliminate / reduce this effect is to make the dipoles very short (reducing the mutual interference) and 'forcing' the desired currents into each feedpoint. This is highly inefficient as the resistance of the feeder and elements becomes comparable with the radiation resistance of the element (that is the resistance presented at the feedpoint, corresponding to the actual radiated energy).
This applies to the antenna when used to receive, too. Only, if you are not pushed for received signal strength and just want to reject interference, you can design effective receiving arrays using 'active' antennas, which act as 'probes' rather than as resonant elements.
