Aerodynamic stabilization of satellites
  • Thread starter Thread starter giber
    Satellites
Aerodynamic stabilization of satellites is a complex topic, particularly because traditional aerodynamic control surfaces are ineffective in space due to the lack of air. The discussion highlights the importance of understanding specific forms of stability, such as spin or orbit stability, when researching this area. Participants mention that atmospheric drag still affects satellites in low Earth orbit, necessitating strategies like torque equilibrium attitude and minimum drag attitude to manage forces acting on the vehicle. Resources for further reading are suggested, including free academic papers that could provide more insights. Overall, the conversation emphasizes the nuanced relationship between atmospheric effects and satellite stability.
giber
i need to do a work about aerodynamic stabilization on satelites.. can anyone help
thanks
Try googling "torque equilibrium attitude".
i don´t find anything about it... all papers to pay, not even examples of satellites... the only information was that URSS send one (cosmos 149) with gravitational and aerodynamic control.. nothing much...
giber,
What, precisely, do you mean by aerodynamic stabilization of satellites? I would presume you know that there is no air in space, and as such any form of aerodynamic control surfaces (such as used on aircraft) are ineffective. And I think you should also define what specific form of stability you are researching: Spin stability or Orbit stability? Suffice it to say that use of the word "aerodynamic" whenever it comes to space (or anything above about 200,000 feet in altitude) is odd.
Rainman
So bypass the pay sites. This one, for example, is free.
http://www.lerc.nasa.gov/WWW/MMAP/PIMS/MEIT/MEIT_pdfs/meit2002/Section19.pdf"
It is not odd at all. The exoatmosphere extends well beyond low Earth orbit. The Space Station's orbit, for example, decays by a few hundred meters per day due to atmospheric drag.
Approaches used by vehicles in low Earth orbit to address atmospheric drag include
  • Torque equilibrium attitude. Atmospheric drag imparts force and torque on the vehicle. The torque depends on attitude. If the vehicle has a non-spherical mass distribution, the gradient in the gravitation field also exerts a torque on the vehicle. Torque equilibrium attitude is the attitude that results in the smallest net torque on the vehicle from the combined effects of atmospheric drag torque and gravity gradient torque.
  • Minimum drag attitude. This is the attitude that minimizes the drag force on the vehicle.
  • Ah f*** it attitude. The vehicle has some science to perform. It pays the penalty and expends fuel to maintain the altitude and attitude needed to carry out its primary mission.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
