Aerodynamics - why wings create lift - current vs historical discussions
The discussion revolves around the mechanisms of lift generation in aerodynamics, particularly contrasting historical explanations like Bernoulli's principle with contemporary interpretations. Participants explore the relationship between differential pressure and airspeed around airfoils, addressing both theoretical and practical implications.
  • Some participants suggest that recent papers imply differential pressure causes speed variance above and below an airfoil, challenging traditional views that speed variance leads to differential pressure.
  • Others argue that the relationship between differential pressure and velocity is co-existent and not strictly cause and effect, emphasizing the role of the wing's shape and the aircraft's forward motion.
  • A participant notes that while Bernoulli's principle is often criticized, it still holds validity in explaining lift when considering airflow dynamics.
  • There is mention of conservation of momentum as a useful framework for understanding lift, particularly in contexts like helicopter flight.
  • Concerns are raised about misconceptions related to the "equal transit time" fallacy and the implications of airflow curvature on lift generation.
  • One participant highlights the importance of reference frames in discussing airflow and pressure, suggesting that the perceived velocity of air relative to the aircraft affects pressure measurements.
  • Another participant points out that the mechanisms of lift generation can be complex and context-dependent, with wind tunnel evidence potentially oversimplifying real flight conditions.
Participants express multiple competing views on the mechanisms of lift generation, with no consensus reached on the primary cause of lift or the validity of different models. The discussion remains unresolved, with ongoing debate about the roles of differential pressure, airflow speed, and conservation of momentum.
Limitations include varying assumptions about airflow conditions, the applicability of Bernoulli's principle under different scenarios, and the complexity of real-world aerodynamic behavior compared to simplified models.
  • #31
sophiecentaur said:
I am confused by the Bernouli adherents’ total attention to the effect on the Plane by the air flow and the curves. The pressures on the wing work in all directions.
That sounds wrong the way you said it: pressure at a surface acts perpendicular to the surface. So as long as you know the shape and orientation of the wing and where you put the pressure taps, you can easily calculate the forces by measuring the pressures. It's a common practice in wind tunnel testing.
  • #32
Klystron said:
During my tenure at Ames (1984-1995) wind tunnel experiments using the Standardized Wind Tunnel System (SWTS) software often collected air flow data from surfaces using an array of pressure sensor pitot valves called scanivalves. I found this eponymous company and from a 1973 PDF instruction set:
Pressure tap - A small orifice on a model surface at which apressure is measured. Pressures are generally measured using a "port" on a "scanivalve".
Pitot or static? I'm familiar with an array of static ports on a wing surface, and that's a distinctly "Bernoulli" approach. I suppose measuring the velocity at the surface would be as well, but I don't see how that would work, because it changes rapidly as distance from the surface changes (and at the surface itself should be zero due to friction in the boundary layer). Previously you mentioned measurement of the downward airflow - for Newton - and that's what I was asking about.
  • #33
A.T. said:
To me, conservation of energy is just as abstract as conservation of momentum. I don't see how invoking one "explains" more than the other.
I agree. My point (and the OP's confusion/impression over the attacks on Bernoulli) is that Bernoulli and Newton are both equally correct. Both describe "what", and neither explain "why". But depending on the situation or approach, either can be more useful. The concern the OP brought to us - which I have seen many times on PF and around the web - is the erroneous impression that Bernoulli's principle is of little or no use at all.
  • #34
FactChecker said:
Why is there a predictable, sustained lift force large enough to lift a 400 ton Boeing 747 airplane?
Why lift is predictable? That's more of a philosophical question. Why should anything be predictable?
Why it has the magnitude it has? That's again a quantitative question about how much not about why. Run a CFD stimulation, look at the results, that's your "why".
  • #35
Doesn’t the word “principle” imply the status of Bernoulli’s calculations? It doesn’t appear to claim to be a Law. But the OP seems to want a ‘why’ reply and that is always difficult when it’s just a mechanism.
  • #36
No, words like "principle" and "law" do not convey any sort of status in science. The word principle is used because Bernoulli's Principle is a verbal description. Why Bernoulli's Equation isn't Bernoulli's law I don't know, but it doesn't really mean anything. Being a "law" doesn't make Newton's Law of gravity absolutely correct, for example.
  • #37
Newton’s gravity law can be observed to work accurately in local ‘space’ (ideal) conditions. Bernoulli never has ideal conditions. Electric forces always mess with it. I would say the two models are very different in that respect.
  • #38
Fair enough - I didn't mean for this to be a competition, I'm only pointing out that Newton's Law isn't exactly correct either, though it may have been believed to be when it was named. There is no governing body that scores them and assigns labels as awards.
Both have known limitations yet both are highly useful when used within those limitations.
  • #39
russ_watters said:
simply insert a term for the energy gain/loss. Then you can apply it as needed.
Which is similar to how it's typically stated for propellers (or rotors), the flow before and after the air crosses the "disc" of interaction, Bernoulli applies, but the flow across the "disc" of interaction, "violates" Bernoulli, because of a jump in pressure (increase in energy).
https://www.grc.nasa.gov/WWW/K-12/airplane/propanl.html
russ_watters said:
it would mean that as airplanes flew, they would eventually force the atmosphere down into a liquid ocean on the surface of the Earth. And that's not a joke; the air has to end up back where it started.
Not quite, the air can't be pushed beyond the ground below, but it can be compressed (eventually it will recover from this as well). Consider the air and a plane flying through the air as a closed system. Over the affected volume of air and area of the earth, the downforce of the air onto the Earth corresponds to the weight of the air and any objects "supported" by the air, (including something like a helium balloon). It's easier to visualize this in a hypothetical closed system, consisting of a large box, filled with air. There's a pressure differential within the box, lower at the top, higher at the bottom, and the net downwards force exerted by the air onto the box equals the weight of the air. Now add a model aircraft flying in a horizontal circle inside the box. The net downwards force exerted on the box now equals the weight of the air and model aircraft (as long as there is no net vertical acceleration of the center of mass of this system), via an increase in the pressure differential within the box.
  • #41
For an initial aircraft design, it's predictable precisely because of the CFD results and because of preliminary wing theory. These days, those estimates are all done before an airplane is built. But for a particular airplane that is already built and flying, the lift is very predictable. It is not just because the lift is not likely to be exactly zero, as you stated.
  • #42
Recent PF threads discussed the type and quantity of air sensing instruments on commercial transport aircraft such as Boeing's 737 series. Wind tunnel tests help decide these design questions.
I have helped collect data from actual valves mounted on sections of aircraft fuselage in full-scale wind tunnels then confirmed by data collected in free flight of a prototype. Earlier experiments might use scale-models of the prototype and an analog of the actual (pitot) valve(s) to optimize placement and minimize distortion once in production.
You may be interested in ground effect experiments conducted in large (12 foot and up) subsonic wind tunnels. Different "ground plates" are added to the configuration that simulate runway conditions at landing and take-off producing fascinating downward and upward air flows. Ground plates are also common in automotive wind tunnels.
My more general point remains that wind tunnel CFD data compares favorably with free flight data and need not be dismissed out of hand because tunnel walls do not dissipate air flow identically to the open atmosphere. Thanks.
  • #43
russ_watters said:
It's also worth noting that the conservation of momentum model also doesn't say why the flow is bent downward, and oddly people don't seem to get bent out of shape over this limitation or its obvious associated misconception:
Often the first time people think about lift is when they stick their hand out the window of a car and make it fly. The simple explanation: the air hits the bottom of your hand and is deflected downward. Heck, you can FEEL it. Momentum transfer! But it is a lot harder to deal with the fact that the air moving over the top of the wing is much more important to lift than the air bouncing off the bottom. The reasons for the air accelerating and curving down over the top of the wing present the same problems/complications for Bernoulli and Newton.
Agreed. The details of exactly why the flowfield is the way it is are equally complicated no matter what your preferred method of looking at it is, and neither of the simple explanations really gets to the root of why airfoils look the way they do to make lift efficiently.
  • #44
sophiecentaur said:
I am confused by the Bernouli adherents’ total attention to the effect on the Plane by the air flow and the curves. The pressures on the wing work in all directions. I know it’s a lot harder to predict the overall flow of the atmosphere (and the losses due to viscosity). But the net downward momentum will meet up with the ground.
I am confused by what you even mean when you say "bernoulli adherents'". As I stated above, all forces on the wing are transferred through pressure, and (for flows slow enough to be considered incompressible, below about mach 0.3 or so) Bernoulli accurately describes the relationship between pressure and local velocity at all points around an airplane. That's not a statement because I'm a "bernoulli adherent", that's simply a fact of the physics involved. Similarly, there will be a downwash after a wing where the momentum flux is directly related to the lift created, but that doesn't make me a "Newton adherent" any more than my pressure statement above makes me a "bernoulli adherent". Both methods of approaching the problem can fully describe the lift, and (as russ said above) neither is very enlightening when it comes to learning why the flow behaves the way it does.
  • #45
Electric forces are pretty much always completely negligible when talking about fluid flow, and Bernoulli is very close to perfectly accurate when talking about any low-speed aircraft flight (less than about mach 0.3).
  • #46
Doesn't viscosity have an effect on the behaviour of the air? Perhaps I should have used the term frictional and turbulent losses instead. Gravitational forces between celestial bodies don't have a similar effect to mess them up. Planetary orbits are the nearest thing to Perpetual Motion that we had, before superconductivity, I think.
I don't know enough to have a serious opinion about Bernoulli but my point is that Bernoulli only considers the air flow very near to the plane and doesn't particularly care about what happens to all the displaced air in the wake of the aircraft.
Bernoulli can be as accurate as you like but it doesn't consider (and probably doesn't need to) the bigger picture. But there is clearly something relevant when you consider ground effect, when lift is very much influenced. The pressure on the air around the wake of an aircraft doesn't have to be building up 'below' it. The pictures higher up in the thread show very large scale motion with air going up at the edges and down near the centre.
If you think of a balloon envelope resting on the ground with a Helium cylinder and the Helium expanding into the balloon until it rises, the total force on the Earth will be the weight of the ballon, it's just that the pressure is very small over a huge area. A similar thing is going on with a heavier than air craft. The total weight of all flying craft is an incredibly small fraction of the weight of the whole atmosphere.
  • #47
For most aircraft, and really a surprising amount of fluid flow in general, viscosity can be completely neglected except in the boundary layer. In general, you will get a very accurate lift value around an airfoil even if you simulate a completely inviscid flow, though the drag will of course be wrong (since a decent amount of drag does indeed come from the boundary layer).
No, Bernoulli is generally true throughout the flowfield, except where there is energy addition or loss (which is pretty much just in the boundary layer and in any engine wakes). Of course, as stated above, Bernoulli doesn't tell you enough to know what the flow will actually do, just how the velocity and pressure will be related at any point in the flow, but the "Newtonian" flow deflection explanation suffers from the exact same problem. If you actually want to know what your streamlines will look like and get quantitative data on how much lift you'll make, neither explanation will cut it and you need to get into some much more complicated models to figure that out.
Again, no simple explanation actually tells you what the flowfield looks like. Bernoulli absolutely can tell you about the lift increase in ground effect, because the flowfield around the wing (and the velocities next to the wing surface) are different in ground effect than they are when the plane is far from the ground. Neither Bernoulli nor the downwash explanation do a good job explaining why ground effect is a thing though. As far as simple explanations go, I prefer to refer to the wingtip vortex formation. The presence of the ground interferes with the full development of tip vortices and decreases the induced downwash angle that the wing sees. This means that for the same global angle of attack (for the airplane relative to freestream), the local angle of attack seen by each wing section is slightly increased, and the lift vector is tilted slightly forwards (due to the inflow angle being more parallel to the flight path). This causes a reduction in induced drag, and an increase in lift, and also explains why the stall angle for an aircraft in ground effect is reduced (which does not make sense if you just think of it as the downwash impinging on the ground).
Sure, but I don't really know what this has to do with the rest of the post. This also doesn't depend on only the downwash explanation - it works just as well if you think of the aircraft as applying a local pressure step across the wing that eventually propagates down to the ground.
  • #48
I did wonder about adding that para but the same thing applies against the argument about 'what happens to the pressure on the ground?' The Earth is massive enough to ignore its Momentum change and the overall CM stays fixed, of course.
The downwash (thanks @cjl for reminding me of that excellent term - I had forgotten it) will transfer Energy to large scale air movement and what goes down must come up - to reverse a well known saying. If you include all that motion then you have a full enough explanation which doesn't clash with Momentum Conservation. Outside of a large enough region of atmosphere, the motion of air will be small enough to ignore but that is well beyond all the local airflow diagrams that are used to explain lift. Without the bigger picture, it relies on sky-hooks, in the end. Bernoulli works ok and that's the main concern for aircraft engineers but why do people reject the idea that something else is at work?
The parallels with simple Antenna Theory are everywhere to see. Assumptions are made which allow antennae to be designed successfully. I can't remember coming across an equivalent conflict between the big and small views. But perhaps it's because EM is so non-intuitive that people don't feel competent to have strong opinions as they do with fluid dynamics.
Interesting. Sounds a good explanation (to someone who knows little about the topic). Could it involve wavelength of the pressure waves and the separation between plane and ground?
  • #49
Just to clarify, the plane does not need to be very high to ignore ground effects. The rule of thumb is that ground effects start when the plane altitude is half of its wingspan or lower. (I personally enjoy the feel of the ground effect during a landing. The plane scoots forward noticeably. I'm not sure why I like that, but I do.)
  • #50
There really isn't a wavelength. If the plane is straight and level, you have a static (unchanging) pressure field surrounding the plane and moving with it. If anything changes that pressure field (throttle, control inputs), those changes propagate away from the plane at the speed of sound. But they aren't coherent waves with a definable wavelength.
  • #51
Not well defined but the circular motion is periodic with a spectrum of ω. wouldn't that involve a delay and hence a wavelength of sorts? A reflection at a boundary plus the delay would produce a temporal filter, perhaps(?) and produce an amplitude / ω response in the vortices. But that idea may well be fruitless, of course.
  • #52
rcgldr said:
You can edit your prior post if you want.
it wasn't letting me, but maybe I am missing something
  • #53
sophiecentaur said:
Not well defined but the circular motion...
What circular motion?
  • #54
The motion inside any vortex?
  • #55
Oh, well having rotation doesn't mean there are emitted waves or a wavelength.
  • #56
The vortex is superimposed on the bulk flow, so there's not really a bulk circular motion. In addition, a potential vortex doesn't have a single period, since the rotational velocity is inversely proportional to radius (unlike a solid body rotation).
  • #57
Which is why I used the word 'spectrum'.
I think you are implying that the ground effect is resistive rather than reactive so it just damps the vortex, rather than reflecting it. That sounds very reasonable.
  • #58
What about a very, very thin wing, just a curved plane. The air would travel the same distance over and under the wing, yet it will still produce lift.
  • #59
The travel distance doesn't matter though. In my very first post on this thread, back on page 1, I even said "the common "longer path length" explanation is completely bogus".
  • #60
A thin curved plane is just a cambered airfoil that has a poor aerodynamic shape; hence, its lifting capability is lower and its drag is higher than those of an equivalent streamlined airfoil.
The Wright brothers experimented with that shape first, but moved to more rounded leading edges, where most of the magic happens.
  • · Replies 30 ·
  • Poll Poll
  • · Replies 16 ·
  • · Replies 30 ·
9K
  • · Replies 16 ·
13K
9K
