Air Compression Shoes: A New Idea
The discussion revolves around a proposed design for air compression shoes that utilize a hind foot air chamber to enhance running efficiency. The concept involves compressing air upon foot strike, which is then released to create a spring-like effect at toe-off, potentially improving propulsion. Concerns are raised about the energy required to compress the air and whether this design could be more efficient than traditional rubber soles or springs. Skepticism exists regarding the practicality of the design, as it may complicate natural running mechanics and require additional effort from the runner. Overall, the idea aims to capture and channel impact energy for better athletic performance, but faces challenges regarding energy efficiency and user experience.
Human268
I had an idea for a type of shoe similar yet different from air Nike, and I would appreciate some comments. A hind foot air chamber would be compressed upon a runners foot strike ( with a force up to three times body weight). The air would be pushed through a one way valve into a rigid mid foot chamber- generating highly pressurized air. The pressurized air would then be released into a forefoot chamber through a check valve as the runners weight is transferred to the forefoot just prior to toe-off. The idea is to generate a spring-like effect at toe-off.
and where does the pressurized air in the forefoot chamber go, and when? If you don't release the pressure in the forefoot chamber, it will remain pressurized and there won't be any further effect.
Likes 1 person
I haven't figured out the details, but the pressurized air in the forefoot chamber could potentially return to the hind foot chamber via a one way air valve or be released, triggered by the straightening of the foot/shoe mid-air.
What exactly is your goal here?
What advantage does this have over rubber soles? (or springs if you're that way inclined)
It sounds like you'll be wasting the runners energy moving and compressing air.
You could just put some springs in there. I think we have had a thread about that before... not sure.
The goal is to capture the energy of impact with the ground and channel it at appropriate time to produce forward propulsion. Goals: energy efficiency, improved athletic performance. Magnets are too heavy, dangerous and their strength decreases by orders of magnitude with tiny changes in position. Springs are used in spira shoes with partial success. Their inherent stiffness and inappropriate timing of energy release are barriers. Same with rubber soles.
release your pressurized air out of the bottom of the shoe during toe off.
It is minimal, but the little thrust from depressurizing would add to forward momentum.
Like they said, I would be worried about it being harder to run because of the additional work the runner does compressing the air.
Wont the runner or walker have to expend more energy to stomp down and compress the air? Some people do stomp around when they walk, but I don't think that is normal. It almost seems like you are trying to get something out of nothing... I think its a better idea to adjust your form so you are not stomping down and not moving up and down much and instead mostly pushing yourself forward. Just my first thoughts... I am skeptical.
Likes 1 person
Good points. Thanks for the input
The most efficient runners strike with the forefoot, not with the heel. This is the natural way to run (barefoot), and it stores some energy in the tendons.
The rather unnatural heel strike in running is a recent development due to shoes with cushioned heels. So you are basically trying to solve a problem caused by cushions with cushions.
More info:
http://www.barefootrunning.fas.harvard.edu/
