Air flow through a hole in a submerged pressure tank
The discussion revolves around calculating the volume air flow through a hole in a submerged pressure tank, focusing on the conditions under which the flow may be choked and the implications for flow rate estimation. Participants explore theoretical approaches, practical testing, and the influence of hole depth on flow rates.
  • Experimental/applied
  • One participant seeks to calculate air flow through a hole in a submerged pressure tank and questions the applicability of certain formulas for choked flow.
  • Another participant suggests that the discharge coefficient should be determined through testing and refers to a specific resource for published values.
  • There is a discussion about estimating flow rates based on the total output of a compressor and the number of holes, with concerns raised about varying pressure differences due to hole depth.
  • Participants express uncertainty about the significance of hydrostatic pressure changes and whether they will affect flow rates across different depths.
  • One participant notes that the initial equation provided is only applicable for incompressible fluids, prompting a search for alternative solutions.
  • Another participant questions whether the fluid will exceed Mach 0.3, which could impact the flow calculations.
  • A later participant shares a solution and references specific equations from a handbook related to compressible flow.
Participants do not reach a consensus on the best approach to calculate the air flow rate, with multiple competing views on the significance of factors like discharge coefficient, pressure differences, and fluid compressibility remaining unresolved.
Limitations include the assumptions made about flow consistency across holes of different depths and the applicability of certain equations to compressible versus incompressible flow scenarios.
Individuals working on fluid dynamics problems, particularly in experimental setups involving pressure tanks and flow measurement, may find this discussion relevant.
Gustav Molin
Hello! I will try to formulate myself as clearly as possible, but english isn't my main language. I'm having trouble solving this problem that should be relatively easy to solve.
Let's say we have a submerged pressure tank, constantly fed with air through a compressor, so it's maintained at a certain pressure Ptank. The pressure tank has a hole in it at a known height from the surface, and with a known diameter, so that air will leak out. I want to calculate the volume air flow through the hole [m3/s].
Can I use the formula
ab1d9a03c9138fa76ad908f3c13cd3bbcefa1d67
to conclude if the flow is choked by using
P* = Patm + rho*g*h
P0 = the pressure in the tube (between 1 and 4 bar or something)
gamma = 1,4 for air
If the flow is proven to be choked, does this mean the air speed is 340 m/s through the hole? Can I then just multiply the speed with the area [m2] of the hole to get the volume air flow [m3/s]?I have tried using this formula but I can't seem to figure out Cd.
a62720a946ef3d47968f53c86c0909d67f8aba47
Thanks in advance!
Is this a homework problem?
No it's not a homework problem. I'm building a test setup for a company, that consists of a tank with multiple holes and want to ensure that the mass flow through every hole is equal.
I believe in this case the discharge coefficient has to be determined via testing. There are published values for this coefficient based on the orifice type and the reference I typically use is table 8-2 in the latest edition of Sutton's Rocket Propulsion Elements. It highlights several liquid orifice types, diameters and the respective discharge coefficient for that kind of orifice.
Here personally, and I may be wrong so if someone thinks I am please let me know - I would love to hear you out, I would start with the volumetric flow rate Q = Cd * A * sqrt(2*ΔP/ρ). If you are feeding the tube with a compressor, the flow rate is that of the compressor output to the tube in total. If each orifice is the same, you can estimate the individual flow rate as the total flow of the compressor / the number of (equal size) outlets.
Thank you very much! I realized that all holes will have the same Cd so if I just guess what the Cd is, I can compare the different holes and calculate the estimated flow rate from there. You say that I can estimate the flow rate by dividing the total flow rate with the number of outlets. Is that true? I am thinking if the holes are placed at different depth, ΔP will differ from hole to hole and therefore the flowrate will differ. Is this correct?
Gustav
Well yes there will be a hydrostatic pressure increase but its not unreasonable to start with assuming a consistent flow rate across all. Is the change in height so significant that the pressure difference will be considerable?
The change in depth will only be maximum 2 meters so maybe the pressure difference isn't significant. I'll try the test setup in a few days, then we'll see if the flow rate really differs at the different depths.
Thank you for being helpful! I really appreciate it
Gustav
I noticed the equation you provided is only applicable for incompressible fluids. This leads me to believe I have to find another way of solving this. Any ideas?
Do you have reason to believe your fluid will exceed Mach 0.3?
I found a way of calculating the air flow rate. Thanks for the help.
Are the holes below the liquid surface and you want the same mass flow of liquid through each hole? What is the hole above the liquid surface for? Please try to state exactly what you want to do, without expecting us to guess.
Clearly, the holes are below the liquid surface and I want the same air mass flow. Air is not a liquid. There is no hole above the liquid surface. Where did you get that from? Please read instead of guessing. Lastly, I already solved the problem, which I stated.
Hi Gustav,
Would be grateful to know your solution please, I am looking at a similar problem.
Regards
Nick
Hi Nick!
Check out section 6-22, at the title "Compressible flow".
I used equations 6-118 and 6-122
https://chembugs.files.wordpress.com/2015/12/perrys-chemical-engineering-handbook1.pdf
  • · Replies 67 ·
9K
