Solving Air Pressure Concepts in Torricelli Experiment
In summary, the conversation is discussing a problem involving a vessel filled with air and placed in a container of water. The change in pressure is being calculated using the formula ΔP = μ(water).g.h, which takes into account the density of water, gravity, and height. There is also consideration for the change in temperature and its effect on pressure through Clapayron's Equation. However, there seems to be some confusion and discrepancy in the given solution.
Pedro Lemos
Well, I'm trying to grasp the concepts behind the following problem :
"A guy puts some air in a vassel, the air's temperature was t0 the vessel's basis area is 50 cm³ and the height is 20. Afterwards the vassel was set onto a container full of water at 300k (Similar to Torricelli experiment), part of the water entered the tube reaching 4 cm of height and then the system acquires equilibrium. The Change in pressure is asked"
The awser is : ΔP = μ(water).g.h ->I don`t understand what formula is that nor that creepy μ.
=-1.10³.10.4.10^-2
=-4,0.10² N/m²
There is a change in temperature as well, so shouldn't this change to be considered as a factor of pressure through Clapayron's Equation p.v=R.n.T?
Apperently I find there's something IS wrong with the solution given.
How is the change in pressure related to μ(water).g.h...the upthrust?
That first number should be the density of water. Normally I see it written as the greek letter rho (looks like a rounded lowercase p). P1 - P2 = ΔP = dgΔh.
It looks like in this situation the pressure difference is negative, as the hot expanded air is being used to suck water into the tube as it contracts. Heat transfer in water is fairly rapid, so the air in the tube should change to match the temperature of the water, thus causing it to cool and contract by Pv=nRT.
Related to Solving Air Pressure Concepts in Torricelli Experiment
What is the Torricelli Experiment?
The Torricelli Experiment, also known as the "Barometer Experiment", is a scientific experiment conducted by Italian scientist Evangelista Torricelli in the 17th century. It involves measuring the air pressure by using a glass tube filled with mercury and inverting it into a container of mercury.
How does the Torricelli Experiment work?
In the Torricelli Experiment, a glass tube is filled with mercury and then inverted into a container of mercury. The mercury in the tube will fall until it reaches a certain height, leaving a vacuum at the top of the tube. This height is directly proportional to the atmospheric pressure exerted on the mercury in the container.
What is the significance of the Torricelli Experiment?
The Torricelli Experiment was significant because it provided the first measurement of atmospheric pressure and led to the invention of the barometer, a device used to measure air pressure. This experiment also helped to prove the existence of a vacuum and laid the foundation for further studies on the properties of gases.
What is the formula used to calculate air pressure in the Torricelli Experiment?
The formula used to calculate air pressure in the Torricelli Experiment is P = hρg, where P is the air pressure, h is the height of the mercury column, ρ is the density of mercury, and g is the acceleration due to gravity. This formula is known as Torricelli's law.
What are some real-life applications of the Torricelli Experiment?
The Torricelli Experiment has many real-life applications, including the use of barometers to measure air pressure in weather forecasting, the measurement of tire pressure in vehicles, and the functioning of vacuum pumps in industrial and scientific processes. It also helped to advance the understanding of gas laws and atmospheric pressure in various fields of science and engineering.
  • Mechanical Engineering
9K
