Calculating Air Resistance Force: Table Tennis Ball Falling at 8.2 m/s
A table tennis ball with a mass of 10 g is falling at a constant speed of 8.2 m/s, leading to the calculation of air resistance. The gravitational force acting on the ball is determined to be 0.098 N, calculated using the formula F = mg, where g is 9.8 m/s². Since the ball is moving at a constant velocity, the air resistance must equal the gravitational force, resulting in an air resistance force of 0.098 N acting upwards. The discussion emphasizes Newton's First and Second Laws, clarifying that the forces are balanced when an object moves at constant velocity. The participants confirm understanding of the concepts, concluding that the forces acting on the ball are equal in magnitude and opposite in direction.
missmerisha
A table tennis ball of mass 10 g is falling towards the ground with a constant speed of 8.2 m/s.
Calculate the magnitude and direction of the air resistance force acting on the ball.
Not quite sure
m= 10 g which equals .01 kg
v = 8.2 m/s
.01* 8.2
= 8.2
Textbook Solution .098N
Not quite sure
v = 8.2 m/s
.01* 8.2
= 8.2
Welcome to Physics Forums,
Let's start from the top. Since the tennis ball is moving with a constant velocity, what can you say about the forces acting on it?
There's an unbalanced force because the object is travelling. Air resistance is opposing gravity in this case.
True.
Not true. I suggest you think about Newton's Second and First Laws.
Newton's First Law states an object will remain at rest or travel at a constant velocity unless there's an unbalanced force.
Newton's Second Law
F= ma
Thinking time:
Gravity
g/a = 9.8 ms ^-2
m = .01 kg
F= .98 N
So gravity has a force of .98 N
Newton's Second Law
F= ma
Thinking time:
Gravity
g/a = 9.8 ms ^-2
m = .01 kg
F= .98 N
You might want to check you arithmetic, but you're on the right lines.
Now know that that the ball is at constant velocity, what can you say about the sum of all the forces acting on it?
I'm still really confused.
The sum of all forces acting on it is equal.
... equal to zero: Correct! So if the weight of the ball is mg, what must be the magnitude of the drag?
wait, I think I get it now
The sum of all forces acting on it is equal because it's traveling at a constant velocity.
hence, gravity and air resistance must have the same magnitude.
using mg
m = .01 kg
g(gravity) = 9.8 m/s^2
= .098 N
Is that correct?
using mg
m = .01 kg
= .098 N
Is that correct?
Spot on :approve:
^THANK YOU! I am no longer confused and I get it now!
=D
=D
It was a pleasure :smile:
