Borja1055
- 2
Hello all,
I am currently installing a 4 station inflation system. My problem is that i do not want to lower the systems pressure when one or two of the stations are inflating.
All 4 stations are fed by a global 120 psi feed. I want to maintain 5 gallons at 80 PSI at each station. To do this, I want to install a regulator with an 80 PSI 5 gallon reservoir at each station (4) to keep a volume of air at the pressure i need.
My question is, can i use only one reservoir to feed the whole system if i set up the tubing in parallel? If so, how would you set it up? Thanks
