Aircraft approaching landing, vector, velocity, position problem. Help
The discussion revolves around calculating the angle of an aircraft's velocity vector as it approaches landing, with given position equations and a velocity vector of 81 m/s in the x-direction and -27 m/s in the y-direction. The speed during descent is calculated to be 85.381 m/s. Participants clarify that the horizontal reference is the x-axis, representing the runway. To find the angle with the horizontal, the correct trigonometric relationship involving the components of the velocity vector must be applied. The discussion emphasizes the importance of visualizing the vectors on an xy-axis to determine the resultant angle accurately.
raven2783
As an aircraft approaches landing, the components of its position are given by:
x=81t y=500-27t
Velocity vector of aircraft during descent is given by:
81m/s (i hat) + -27m/s (j hat)
The value of the speed during the descent is:
85.381m/s
What angle does the velocity vector make with the horizonal?
2. The attempt at a solution
I tried the Law of Sines sin90/85.381=sina/-27 and sin90/85.381=sina/81 but the angles of this triangle other then 90 are not what they are looking for. What do they mean horizontal?? help!
The horizontal would be your x-axis; in this case, the runway. Draw the velocity component vectors on an xy-axis. Now draw your resultant vector (the hypotenuse), which you are trying to determine the angle of. What trigonometric relation will give you this angle?
See link for formulas:
http://en.wikipedia.org/wiki/Trigonometry#Overview
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
