Airflow Across a Persistent Cold Air Pool in a Basin
The discussion focuses on the fluid dynamics of airflow over a persistent cold air pool in a parabolic basin, particularly under varying wind conditions and temperature inversions. It raises questions about how airflow aloft interacts with the cold air pool, specifically regarding mixing and the impact of a screen covering the basin's aperture. The presence of a temperature inversion is expected to minimize mixing, while the dynamic pressure of warm air advection could create lower pressure in the basin, affecting air volume. The conversation also speculates on the flow characteristics, suggesting that airflow may be laminar to transitional, and how this influences mixing dynamics. Overall, the complexities of modeling these interactions remain a challenge due to the lack of specific information in existing literature.
skyfridge
This question is regarding the general fluid dynamics involving warm air advection aloft a persistent cold air pool in a small basin that is recessed in a horizontal planar surface. For scale, the basin has a compound parabolic shape, with a 30° viewing angle, a .146m radius at the base, a .292m radius at the aperture and a height of .759m. It has a temperature inversion at the base, with a temperature at the base that is up to 40°C below the ambient temperature aloft.
Angus[1] compares a simpler enclosure uncovered and covered with a polyethylene mesh, under mild winds.
In attempting to answer the questions, I have researched multiple disciplines, including general science, fluid dynamics, meteorology, greenhouse ventilation, building wind loads and agriculture, but I haven't found any specific information to answer the questions.
(1) How would airflow aloft the uncovered basin mix with the cold air pool in the basin under different wind speeds? Specifically, would the temperature inversion minimize mixing? What equations model this case?
(2) To what degree would a screen covering the aperture or recessed in the basin affect mixing of the advection with the cold air pool? What equations would model this case?
[1] Performance comparison of sky window spectral selective and high emittance radiant cooling systems under varying atmospheric conditions, Dr Angus Gentle, Prof Geoff Smith
Also, the dynamic pressure of the advection across the aperture would be
q=1/2*ρ*t^2
so the advection would be at a lower pressure than the volume in the basin. What does that do to the volume of air in the basin?
I'm picturing a vertical pipe filled with water with an inverted temperature gradient and water moving across the top of the pipe. Since the temperature decreases and thus the density increases from top to bottom in the vertical pipe, I might assume that would lessen the mixing. Does the volume of air act like a surface, preventing or minimizing the advection from circulating into the basin?
The flow across the horizontal surface would probably be laminar to transitional, but I'm guessing. How would that affect the mixing?
A screen atop the basin would probably make it turbulent. Would the advection across the uncovered (or basin with a recessed screen) basin also be laminar to transitional? How does that affect the mixing?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
