Airplane and Conveyor Belt Debate
The debate centers on the behavior of a Boeing 747 jetliner weighing 163,844 kg when landing on a treadmill moving in the opposite direction at 200 kph. Participants agree that the plane will continue to move forward off the treadmill, as the wheels will rotate at a speed that combines the treadmill's speed with the plane's landing speed. The consensus is that the landing gear would experience excessive stress due to the high rotational speeds, potentially leading to overheating and failure. The discussion highlights the importance of understanding aerodynamic principles and the effects of friction on landing gear during such scenarios.
  • Understanding of basic physics principles, particularly Newton's laws of motion.
  • Familiarity with aerodynamics, specifically the Bernoulli principle and the Venturi effect.
  • Knowledge of aircraft landing gear mechanics and stress factors.
  • Experience with the dynamics of motion on moving surfaces.
  • Research the effects of friction on landing gear during high-speed landings.
  • Study the principles of aerodynamics, focusing on lift generation and drag forces.
  • Learn about the mechanical design and stress tolerances of aircraft landing gear.
  • Explore real-world applications of the Venturi effect in aviation and fluid dynamics.
Aerospace engineers, physics students, aviation enthusiasts, and anyone interested in the mechanics of flight and landing dynamics.
  • #241
For arguments sake we'll say that braking is done the way a 747 usually brakes, that being reverse thrust and wheel brakes.
Your answer seems like it doesn't follow the question, although that is probably my fault. Let me restate.
A plane is landing. Instead of a long runway, you have a short conveyor belt. The plane is travailing 100mph north. The conveyor is not going anywhere, but it's speed is 100mph, south. The plane lands on the conveyor belt and the conveyor is slowed from 100mph to a stop. If the plane lands on the conveyor belt, and its forward momentum is transferred into the conveyor belt, will it stop without the need for a long runway with no adverse effects on the plan or passengers? Will the conveyor belt negate it's forward inertia?
My argument is that when the plane touches down, if it does stop, it will probably destroy the plane and/or kill the passengers because it's inertia is cut abruptly, being that I don't believe that the conveyor belt will "catch" the plane's inertia. Alternatively, is it even possible to stop the plane on the conveyor belt, as the plane's 100mph is air speed, and the conveyor belt's 100mph is ground speed?
  • #242
I agree with Mgb. Under normal circumstances, with a light passenger aeroplane, you don't use the toe brakes until it's time to turn from active to a taxiway. Runways are long enough that the bird slows down just fine by itself; differential braking is used for steering. If you did apply the brakes on a conveyor belt, something would come unglued.
  • #243
If it takes the same time for the conveyor to stop the plane - there is no difference, if it takes less time there will be more force on the plane and passengers.
If the plane lands on the conveyor doing 100mph in the opposite direction then you just have to (wheel) brake more gently.
It's exactly equivalent to landing with a 100mph tailwind - you would have the same indicated air speed but would probably blow all the tires !
  • #244
The thing that people fail to realize is that, no matter what the wheels are doing, the forward flight of the aircraft is the wing relative to the surrounding air. When you're coming in at, say, 100 MPH IAS, that means the wing has a relative velocity to the wind of 10 MPH. The ONLY way this would work is if you had a wind generating device that matched the required wind speed at the second the wheels hit the ground.
  • #245
OMG. Kill one plane-on-a-treadmill myth and another just as ludicrous in from its ashes.
The MythBusters already addressed this new incarnation as well. They drove a car up a ramp trailing behind a moving truck. The car's wheels changed their rotation rate nearly instantly as the car transitioned from rolling at speed with respect to the road to nearly at rest with respect to the ramp. The bulk of the car's momentum is in the car, not the wheels. The same applies to the plane landing on a moving treadmill. The bulk of the plane's momentum is in the plane itself, not the wheels.
In this case, problems would arise should the pilot stupidly lock the brakes the instant the plane hit the conveyor belt. So what? Problems would arise should the pilot stupidly lock the brakes the instant a plane hits a run-of-the-mill tarmac.
  • #246
I guess what I can't conceive here is that the plane is going forward, and when it hits the conveyor belt, it isn't supposed to go forward any more. The idea being that it really is still going forward, but on the conveyor belt now. This just doesn't seem possible to me.
  • #247
The plane has free-rolling wheels. The plane landing on a moving conveyor belt is no different physically than a plane landing an a normal runway while flying with a tailwind or against a headwind.
  • #248
Exactly. It's the application (if any) of the brakes that makes the difference between this and the take-off scenario. Suddenly, they're no longer free-rolling. You're quite correct that the effect would be the same as locking them up upon first touching a runway. Most tricycle gear planes wouldn't mind too much, but it could be devestating to a tail-dragger.
  • #249
See, I would think that the plane would continue off the end of the conveyor, as it still has it's main forward inertia through space.
Maybe this is what your saying...
  • #250
Hehe, just finished watching the new Knight Rider!
  • #251
Loved it! A lot less hokey than the original, and I really liked the way that they integrated Hasselhoff into it. I knew that he was going to be a guest star, but I expected some crappy 'formula' type of approach. This was handled very nicely. It was great that it was a stand-alone movie (ie: no cliff-hanger), but still left me wanting more. I hope that they pick it up as a series.
  • #252
Do you think an aircraft carrier is stationary when those airplanes land on it?
QED
How many times do we have to hear this crapy question?
Thread locked, poster banned.
  • #253
Do you think that Earth is stationary when an aeroplane lands on it?
The question still comes down to the matter of having or not having brakes applied.
  • #254
The difference being that the aircraft carrier is moving the same direction the plane is landing. Not only that, but it still doesn't answer the question of stopping in a small space. When those jet fighters stop abruptly on an aircraft carrier, they use giant tow wires and stop quickly enough to jerk the pilots around.Also, I humbly apologize for wanting to know more about the world around me.
So what your saying is that if there are no brakes applied, it will continue off the conveyor, but if brakes are applied it will stop quickly?
  • #255
Yes - imagine a plane landing on ice with skis if you prefer - it doesn;t matter what the ground is doing.
Yes - the brakes will have to be applied a bit more gently because you don't want them to go backwards as soon as the touch.
  • #256
This has been done
Actually the idea of "landing on a conveyor belt" has already been tested, though not by Mythbusters.
At an airshow, a small plane was landed on what was billed as "the world's shortest runway" as a stunt.
A large platform was mounted to the top of a motorhome. The motorhome matched the landing speed of the small plane, speeding up and slowing down as necessary to stay under it as it landed.
As you might expect, the wheels of the plane barely turned as they settled on the platform.
Once the plane had settled its weight on the platform the motorhome simply slowed to a stop.
Here's a link to where you can see it on YouTube:
  • #257
It is still going forward wrt the ground and air. The conveyor belt has no way to stop the airplane besides making the wheels spin faster and increasing the braking force.
Btw, the first answer you got (and pretty much everything that followed followed it) is correct.
Sorry, this thread isn't any better than all the other ones on the subject that we've banned. It's a simple question that people make just complicated enough to confuse themselves. Drop the complications and listen to the simple answers. There was nothing wrong with the Mythbuster's test - you're adding irrelevant complications to it and convincing yourself they matter. They don't.
Locked.
  • #258
Misconception of friction
I think some people may have a misconception of friction, including me about ten minutes ago.
As I set out to demonstrate a stationary plane due to frictional forces the wheel bearings place on the plane I found a problem in my logic. I had imagined a different universe in which friction INCREASES with velocity, which, I found out, didn't happen to be true in my current universe.
If the friction increased proportionally in the wheel bearings with the increase of the rotation of the wheels, then it seems reasonable that we could arbitrarily set the backwards force due to friction on the plane to exactly equal the forward thrust simply by increasing the conveyor speed.
As I understand it, friction only depends on the Coefficient used and the Force between two objects. And, both the Coefficient and the Force (gravity and mass of the plane) remain constant in the case of the plane-on-a-conveyor experiment. So, what force am I missing that is canceling out the forward thrust?
But what if we changed the experiment to allow ridiculously high friction wheels? Assuming a fully loaded Cessna 182 weighing in at 1160 kg and a thrust of 1,000 N the normal forward force (with coeff of friction 0.001 for the wheel bearings) would be 1,000N - 1160kg * 9.8m/(s*s) * 0.001 or about 990N. But if the wheels had a coefficient of friction of, say, 0.088 (the coefficient of sliding friction of copper on copper) then the total forward force would be about 0N which means the conveyor would create enough force via friction to keep the plane stationary. But I don't know of any wheels that use copper slabs in place of bearings.
Do I have an error in my calculations of this last example (besides blatantly ignoring significant digits)? I've been out of physics for quite a while now. Maybe I should be using rolling friction for the wheel bearings, and it doesn't have anything to with the weight of the plane?
  • #259
I Googled Cesna and found a picture of the instrument panel. The "speedometer" is unmistakably an air speed indicator.
  • #260
The ATR 42/72 (a french twin turboprop commuter) is almost unique in having powered wheels so it can be manouvered easily in small airports without the props running. So it might also be the only aircraft with a speedometer!
edit. Of course this has nothing to do with conveyor belts
  • #261
have you seen the chopper on a turntable version?
  • #262
lol, That made me laugh. A whole new ball of wax has just opened up before my eyes.
  • #263
airplane thrust
Hi everbody, I,m new on here but had to join looks really interesting, however the real reason for searching out a forum like this is to try and have a question answered that was put to me and is really niggling me.
Please take a look at the question I have pasted . Can you help with the correct answe and reason why?
geoff
An aircraft is standing on a runway that can move. The aircraft can move in one direction, while the conveyor belt moves in the opposite direction. This conveyor has a control system that tracks the aircrafts wheel speed and tunes the speed of the conveyor to exactly the same as the wheels, but in opposite direction. There is no wind,
The pilot begins to add thrust to the engines.
Will the plane take off
  • #264
Damn it, this was even tested on Mythbusters.
Aside from some increased friction in the wheels, there will be no effect. It will take off normally (assuming you don't have a massive backward starting velocity that would screw the plane up.)
I don't think an airplane that provided its thrust through wheels would be very effective.
  • #265
geoff
This has been discussed at length. A search on the PF for "conveyor" finds the threads pretty quickly.
https://www.physicsforums.com/showthread.php?t=212151&highlight=conveyor
Thread locked.
  • #266
Treadmill and an airplane
NOTE: Never mind the question! I anwered it myself.
Anyway, if you want to read it:
I search quickly, but if this has been posted, please direct me and delete this threads...Anyway:
There was a mention in the XKCD this week about the airplane/treadmill connundrum. I am including the wording I found below:
"plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction. This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in the opposite direction). Can the plane take off?"
So, everyone who claims to be a physicist says it will take off. If it was just a free standing belt that could spin, I would agree, but I think the way it is asked the airplane will not take off.
Assume bearings that are frictionless bearings but not frictionless wheels. So, once the plane starts moving forward, the treadmill will accelerate backwards creating a force on the wheels. So, the way I see it, the treadmill and wheel speed will increase unbounded, but in a perfect system, this will stop the plane from moving. The belt would have to be constantly accelerating or else the plane will take off.
A lot of people argued that it is like a plane taking off on water where it just moved forward, but this is not the same situation. The belt is ACTIVELY moving backwards.
Does my analysis make sense?
  • #267
Nevermind. I thought about it more and realized that while the wheels and the treadmill speed will increase, the thing that is interesting is the force on the air and the plane will move forward.
My flaw was that if you have a stationary plane and turn on the treadmill, the wheels will turn but the plane will not in the ideal situation.
So, nevermind...
  • #268
Oh dear god not this stupid question again.....
The answer, of course, is that the airplane does take off. Search the forums if you want to know why. This thread is locked.
We need a big bold disclaimer saying DONT POST THIS QUESTION ON THIS FORUM ANYMORE!
  • #269
My tentative answer:
Consider a plane on a rigid surface with only static friction (Fr) that increases with applied force up to a maximum (Frmax).
In the case of a plane without wheels, the plane cannot accelerate unless the jet force (Fj) is greater than Frmax. In this case, the plane will take off, since the puzzle doesn't even make sense unless Fj>Frmax.
But a plane with rigid wheels can accelerate if Fj is less than Frmax, which is reasonable if we assume the wheels always roll without slipping.
Assume Fj is applied through the center of mass of the wheel of mass M, radius R and moment of inertia about its axis I.
Let Ap be the translational acceleration of the wheel relative to the ground.
Let alpha be the rotational acceleration of the wheel about its axis.
Let Ab be the translational acceleration of the belt relative to the ground.
1: Fj-Fr = M*Ap (used 'F=ma')
2: Fr*R=I*alpha (used 'torque=I*alpha')
The plane is moving forwards, the belt is moving backwards, so the translational acceleration of the plane relative to the belt is (Ap+Ab), so for rolling without slipping:
3: (Ap+Ab)=alpha*R
Solving for the friction gives:
Fr=I*(Fj+Ab*M*R^2)/(I+M*R^2)
Thus if Ab=0, then Fr<Fj, and the plane can accelerate.
But for sufficiently great but finite Ab, then Fr=Fj, and the plane cannot accelerate by rolling. It also cannot accelerate by sliding since Fj<Frmax.
  • #270
Cyrus says it all!
  • · Replies 63 ·
  • · Replies 127 ·
17K
  • · Replies 81 ·
12K
9K
10K
  • · Replies 54 ·
11K
