Algebra 2 - residual^2 or something ?
  • Thread starter Thread starter offtheleft
    Algebra Algebra 2
The discussion revolves around finding the correct equations for a function representing failed parts on an assembly line based on three data points. The user initially struggles with deriving the equations and calculating residuals, particularly expressing the relationships between points A, B, and C. After some back-and-forth, they identify a mistake in their equation from A to B, realizing it should be y = 20x + 20 instead of y = 20x - 20. They successfully construct tables for residuals and confirm the equations for A to C and B to C, leading to a better understanding of the problem. The user expresses gratitude for the assistance and feels more confident in proceeding with their work.
offtheleft
i have a function y=f(x) with three points;
A (1, 40)
B (3, 80)
C (5, 90)
the x model represents days. and the y model represents failed parts on an assembly line.
the question is: how many failed parts will have been identified 1 week from now?
I have no problem with doing the work, getting the slopes, figuring out all the algebraic gymnastics and getting the equations.
heres what i have:
A\rightarrow B, y=20x-20
A\rightarrow C, y=\frac{25}{2}x+\frac{55}{2}
B\rightarrow C, y=\frac{77}{5}x+26
I actually think my equation from B\rightarrow C could be incorrect.
now, the part that is getting me is I am trying to get the residual? i need to get some medication because my ADHD is seriously out of control. its getting worse as i get older.
i need to construct some table... this is what i have for the first one:
real obverved measures residual
x,... y,... y_{1}=20x-20,... (y-y_{1})^2
1,... 40, ...40, .....0
3,... 80, ...80, .....0
5,... 90, ...120, ...900
x,... y,... y_{2}=\frac{25}{2}x+\frac{55}{2},... (y-y_{1})^2
1,
2,
3,
not quite sure how to do all of this. :(
You might want to check your equation for A to C as well as from B to C...
I am assuming of course you want to write an equation that goes through both those points in y = mx +b form.
Other than that I can't help you because I don't really understand the question. I know you want to predict what y is when x is 7, but there are many methods of doing this and I am not sure which one you are supposed to be doing.
Here are my Equations:A\rightarrow B, y=20x-20
B\rightarrow C, y=5x+65
the first two are correct because we did them in class. the third i just corrected, there was a minor mistake in my arithmetic that knocked everything off the rocker.
now, i have to do something with the y points A(1,40) B(3,80) C(5,90)
what i have to do for this table
I have each point
I think A -> B is incorrect!
y = 20x - 20
If this is supposed to go through the point A(1,40) then when I put 1 in for x I should get y = 40.y = 20(1) - 20 = 20 - 20 = 0
So y = 20x - 20 does not go through the point (1,40) it goes through (1, 0)
It's probably just a typo from you notes from your class, but the correct equation should be y = 20x + 20
y = 20x - 20
YOURE RIGHT! i actually got the answer early in the class which was y=20x+20 i don't know why its copied incorrectly thereafter
"y = 20(1) - 20 = 20 - 20 = 0"
how would i construct a table just as that for the other two equations... but, there was three parts to each. one for the Y value for each point.
I'm sorry can you elaborate on the table you are supposed to create, I don't really understand that part.
x,... y,... y_{1}=20x+20,... (y-y_{1})^2
i think i finally understand it. because i had the equation copied wrong it all came out wrong, the numbers didnt match up and it threw me off.
<br /> y_{1}=20(1)+20=40
and the residual thing. i take the real y which is 40 and subtract it from the new y which is 40: <br /> y_{1}=20(1)+20=40
(40-40)^2=0
let me try and set this up
my line: y=20(1)+20=40, (40-40)^2=0
y=20(3)+20=80, (80-80)^2=0
y=20(5)+20=120, (120-90)^2=900
<br /> B\rightarrow C, y=5x+65
y=5(1)+65=70, (70-40)^2=900
y=5(3)+65=80, (80-80)^2=0
y=5(5)+65=90, (90-90)^2=0now, i have to figure out where i went wrong with the second line.. from A\rightarrow C.
i don't have my notebook with me at the moment though, ugh.
just worked it out and the second equation is correct
<br /> A\rightarrow C, y=\frac{25}{2}x+\frac{55}{2}y=\frac{25}{2}(1)+\frac{55}{2}=40, (40-40)^2=0
y=\frac{25}{2}(3)+\frac{55}{2}=65, (80-65)^2=225
y=\frac{25}{2}(5)+\frac{55}{2}=90, (90-90)^2=0thanks for all the help! i think i may be able to hold it down from here, until class on tuesday :p
