Help! Solving for y in 2x^2 + 12x - 14
  • Thread starter Thread starter jellybelly
To solve for y in the equation x = 2y² + 12y - 14, one must first rearrange the equation to isolate y. This involves moving terms around to form a standard quadratic equation. The discussion highlights the need for assistance in isolating y and understanding the nature of the equation. The equation is identified as a quadratic in y, which can be solved using the quadratic formula. The user expresses frustration in finding help, emphasizing the importance of clear guidance in algebraic manipulation.
jellybelly
algebra help!
f(x) = 2x^2 + 12x - 14 *it's 2xSQUARED
how do you find the inverse of this equation??
x = 2y2 + 12y - 14
x + 14 = 2y^2 +12y ...How do you isolate "y" ??
I've been posting on as many sites as I can but no one has been able to help me!
any help is appreciated!
thankS!
kelsey
Mathematics news on Phys.org
What kind of equation is x = 2y² + 12y - 14?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
