How do you solve this algebraic equation without using a calculator?
In summary: Good job on figuring it out! Factoring is definitely the way to go for this problem. And don't worry about wasting my time, it's always a pleasure to help someone understand a concept better. Keep up the good work!In summary, the conversation discusses how to solve the equation 4x+8=33x^{\frac{1}{2}}, without using a calculator. The suggested method is to substitute t for x^{\frac{1}{2}} and then use factoring to solve the resulting quadratic equation. The conversation also touches on the rational roots theorem and provides tips for finding the roots. Ultimately, the conversation concludes that the correct solution is t=8 and 1/4, which can be found by
Mukilab
73
How would one solve the following WITHOUT a calculator?
Sub in t as [itex]x^{\frac{1}{2}}[/itex]
[itex]4x+8=33x^{\frac{1}{2}}[/itex]
I just don't see how to do this without a calculator.
If I take t^2=x, then sub it in I need to do the quadratic formula which is too hard without a calculator/would take too long in an exam. Even if I do the formula I get t=8,2 which I would then need to square route to get x but would be the wrong answer since x = 64 and 1/16...
Any help. Is t^2=x a wrong assumption? Surely it is right since x^1/2 squared gives x?
Mathematics news on Phys.org
Your substitution is the right one. After making the substitution, you will have a quadratic equation that can be factored.
There are two solutions for t. One solution for t is t = 8, but your other solution (t = 2) is not a solution.
Please show us your work.
Sorry for not showing my work, I just did so much and failed I thought it would be useless.
Nonetheless I tried 4t^2-33t+8=0 and then factoring that but without using the quadratic formula to give me the answer of t=8, I didn't see how else I could do it (the quadratic formula requiring a calculator since you have to square 33 to make 1089 and then get a square route...).
Then I tried factorising it into 4(t^2+2)=33t but I didn't really see where to go from there. Most of my working has just been repetitions of these.
I'm fairly sure that you can factorise it into (2t + 16)(2t + 1/2) but there was no way I would have ever gotten that without a calculator, so it is again useless.
Do you know of any methods through which to solve this?
Thanks for replying!
Quadratic formula workings; (33+sqrt(33^2-4(4)(8)))/8=8, 1/4
But then 8 and 1/4 are not the right answers (the answers are 64 and 1/16) :(
But then, how can 8 and 1/4 be the answers if in the ( )( ) equation they will have to multiply to give 8? Surely it must be 8 and 1?
You made the transformation t = x1/2. You have the roots for the polynomial in t, so convert them back to x.
The roots would be 2(sqrt2) and 1/2 however that's not the right answer (the right answer being 64 and 1/16).
That still doesn't answer how to do it without a calculator though. Got any insights?
You can try the rational roots theorem
if a rational number p/q is a root of the polynomial
[tex] a_n x^n + a_{n-1} x^{n-1} + ... + a_0 [/tex]
then p is a factor of a_0 and q a factor of a_n.
In case of 4t^2 - 33t +8 =0, you get p = 8 or 4 or 2 or 1 and q = 4 or 2 or 1.
possible roots are 8,4,2,1,(1/2),(1/4), you just try all of these. Test exercises
nearly always have rational roots.
The producut of the roots is a_0 = 8, so if you found one root, the other is easy.
You don't need the quadratic formula. Factoring works just fine.
Breaking up the equation as you show here is a complete dead end.
Your factors here are incorrect. They should multiply to 4t2 - 33t + 8, but instead they multiply to 4t2 + 33t + 8.
Yes - factoring. You should have been exposed to lots and lots of trinomial factorization problems in your algebra class, including some where the coefficient of the squared term wasn't 1. Do you remember doing this?
I talked to my friend about this and he pointed out that you can factorise it into the brackets
(4t-1)(t-8)
Giving t=8,1/4
And since t=x^1/2, you need to square 8 and 1/4 rather than square routing it like I was doing.
Sorry for wasting your time, this turned out to be a very elementary mistake.
(4t-1)(t-8)
Giving t=8,1/4
Yes, that's exactly it.
1. What is "Algebra without a calculator"?
Algebra without a calculator is the practice of solving algebraic equations and problems without the use of a calculator. This requires a strong understanding of algebraic concepts and the ability to perform calculations mentally or with pen and paper.
2. Why is it important to learn algebra without a calculator?
Learning algebra without a calculator helps develop critical thinking and problem-solving skills. It also provides a deeper understanding of algebraic concepts and prepares students for more advanced math courses.
3. What are some tips for solving algebra problems without a calculator?
Some tips for solving algebra problems without a calculator include simplifying expressions, using mental math strategies such as the distributive property and factoring, and checking your work for accuracy.
4. Can I use a calculator to check my work when solving algebra problems without a calculator?
Yes, it is always a good idea to check your work using a calculator when solving algebra problems without one. This can help catch any errors and ensure the accuracy of your solution.
5. Are there any resources available for practicing algebra without a calculator?
Yes, there are many online resources, textbooks, and workbooks available for practicing algebra without a calculator. You can also find practice problems and worksheets from your math teacher or tutor.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
