Understanding Dominance of Rational Maps in Algebraic Geometry
  • Thread starter Thread starter Diophantus
    Geometry
Dominance in rational maps is crucial in algebraic geometry, as a map is dominant if its image is not contained in a proper subvariety of the target variety. This property ensures that compositions of rational maps make sense, as non-dominant maps may lead to undefined points. The discussion highlights that a rational map must be defined on a dense subset of its domain, and if the image lies in the complement of where the second map is defined, the composition becomes problematic. Dominant maps can be viewed as "essentially surjective," similar to epimorphisms in topology, allowing for meaningful compositions. Understanding dominance clarifies why certain compositions are valid and helps navigate the complexities of rational maps in algebraic geometry.
Diophantus
I'm having trouble understanding the importance of dominance with regards rational maps.
I have the definition that a rational map phi (from some affine variety V to an affine variety W) is dominant if the image of V is not contained in a proper subvariety of W.
In my lecture notes there is some remark about how if we compose phi with another such map psi going in the reverse direction W to V (to get a map V to V) then it may not make sense unless phi is dominant.
Whilst reading around the subject I have noticed that the notion of dominance crops up in a lot of theorem hypotheses so I really feel I ought to get a grip on it.
My problem is this: Rational maps are not generally functions anyway since they may have undefined points. OK. Now, in the remark when it talks about the composition 'not making sense', one would usually assume by the phrase 'not making sense' that it has undefined points - but why are we suddenly bothered about this now when we weren't before?
Any help would be greatly appreciated.
Mathematics news on Phys.org
A rational map must be defined on an dense subset of the domain, right? Well, what if the image of f lies in the complement of the set where g is defined?
Explicit examples are fun: let's use R^2.
Let f be the map (x, y) --> (1/x, 0)
Let g be the map (x, y) --> (0, 1/y)
What is their composite? (Either way)
Also, I suspect that dominant maps are epimorphisms (f is epimorphic iff g o f = h o f implies g=h), and so play a similar role that surjective maps would in topology.
You should think of dominance as being 'essentially surjective'. It is the definition that makes rational maps composable. As you say there might be a set of points on which they are not defined - that is a subvariety of dimension 0. Each composition of dominant maps, adds at most finitely many more points that are bad. And a finite sum of finitely many things is still finite, so a dimension 0 subvariety. If you dropped the dominant assumption you can get a situation as in Hall's post above.
I didn't know this but it certainly makes sense now you say it. Topology wasn't a prerequisite for this course so the lecturer has avoided topological notions. (I have done toplogy though.) I know about the Zariski topology so it seems that dense here means a subset A of our variety for which there is no closed set (i.e. a subvariety) which both contains A and is contained in V. So nicely enough NOT being dominant means that our image of V is not a dense subset of W. It's starting to make sense now.
Of course the image of either composition is the empty set.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
