All Solution of Diff. Eq. Tend to Zero
  • Thread starter Thread starter TranscendArcu
    Zero
TranscendArcu
Assume that a,b,c are all positive constants. Show that all the solutions of:
ay'' + by' + cy = 0
tend to zero as x goes to infinity. (I presume that y is implicitly assumed to be a function of x)
This is what I have to far:
We write the characteristic polynomial: ar^2 + br + c = 0 and solve using the quadratic formula. Thus, we find two roots for the equation, call them r_1 , r_2. We can write solutions if we presume there exist solutions of the form y = C * exp(r*t). Thus, we have:
y_1 = c_1 e^{\frac{-b + \sqrt{b^2 - 4(a)(c)}}{2a}}
y_2 = c_2 e^{\frac{-b - \sqrt{b^2 - 4(a)(c)}}{2a}}
To show that a linear combination of these two solutions always tends to zero, we'll need that the exponents of e are negative. We must show that |\frac{-b}{2a}| > |\frac{± \sqrt{b^2 -4(a)(c)}}{2a}| which implies |-b| > |± \sqrt{b^2 -4(a)(c)}|. We know that b = \sqrt{b^2 - X} iff X = 0. By assumption, however, a,c are nonzero, so we must have some number inside the radical, call it Q = b^2 - X such that |-b| > sqrt(Q). Thus, we have that all exponents are negative.
I'm not sure if this is right, or even if this is true for all cases. Do I need to do cases for instances where the exponents have complex elements?
Yeah, that works. It just seems a little overcomplicated. In the case where you have two real roots then you can factor your equation ar^2+br+c=a*(r-r1)*(r-r2). You don't really need the quadratic formula to say something about the signs of r1 and r2. You do need to think about the case of complex roots. If they are complex then r1 and r2 are complex conjugates. What can you say about the sign of the real part? And there is a third case you should mention. Where r1=r2. The solution looks a little different in that case.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
