Altering Images for Corrective Optics: Details Appreciated
  • Context: Undergrad
  • Thread starter Thread starter Eshez
    Optics
The discussion revolves around the possibility of altering images to correct vision problems without the use of glasses. Participants explore the feasibility of optical distortion techniques to enable individuals with common eye issues to perceive images clearly. The conversation touches on theoretical and practical aspects of corrective optics.
  • One participant questions how to optically distort an image to appear sharp for someone who is near-sighted without glasses or pin-hole viewing.
  • Another participant suggests that the question may be poorly defined, noting that correcting a blurry image is not feasible, but that it might be possible for specific distortions like astigmatism.
  • A later reply proposes that for common eye problems, it may be possible to distort an image so that it appears correct, depending on the nature of the vision issue.
  • One participant asserts that an image cannot be made to look correct when out of focus, emphasizing that glasses function by converging parallel rays to form an image.
  • Another participant explains that using a lens can produce an image that a defective eye can see properly, distinguishing between distortion and translation for various vision defects.
  • A mention is made of a novel device developed in Edinburgh that modulates phase to control laser tweezers, which may relate to the concept of image distortion.
Participants express differing views on the feasibility and definition of the problem. While some agree that certain optical corrections are possible, others emphasize the limitations and challenges in formulating the question clearly. No consensus is reached on the specifics of the proposed solutions.
The discussion highlights limitations in understanding the nature of various eye problems and the complexities involved in optical corrections. There is an acknowledgment of the need for clearer definitions and specific questions to facilitate more focused responses.
Eshez
Hello.
I was wondering about the following question.
Let's say I have a certain image. Given ones' galsses parameters, is it possible to alter the image in such a way that he will see it "correctly" without the need of glasses?
If so, is that a rather complicated task or a simple one?
Thanks in advanced.
Details would be appreciated.
Cheers :)
Science news on Phys.org
I'm not sure how one could optically distort a distant image to appear "sharp and distinct" to someone who is near-sighted without their glasses or pin-hole viewing.
Good question though.
Is this question too hard or do I have to be more patient? :)
Anyone can tell me where else I can seek for an answer?
Thanks
Too hard? No, but probably too poorly defined. As pointed out, you can't correct a blurry image. If someone had a distorted view, perhaps because of a weak astigmatism, it might be possible. It depends on what's wrong with their vision.
Than let me rephrase.
For which of the common eye problems would it be possible to distort an image in such a way that the person having the eye problem would be able to see the image "correctly"?
I don't know much physics and don't know a whole lot about common eye problems.
Thats why i'd love to see detailed answers :)
Thanks
No you cannot make an image which will look correct when out of focus.
You can make an optical system which distorts the object by making parallel rays converge so that someone who cannot normally focus them is able to form an image - but that's what glasses do.
The easiest way to "distort the image" so that you see it properly is to use a lens between your eye and the object. The lens produces an image of the object that the defective eye will see properly. This is how eyeglasses work.
For most defects (nearsightedness, farsightedness) it's not really a distortion but just a "translation". For astigmatism you can probably say that the lens "distorts" the image.
You can use more sophisticated methods I guess but as Vanadium 50 remarked, your question is very poorly formulated. It gives the impression that you don't have a specific question in mind but just something vague. (and still expecting a specific answer...)
One example of novel and fancy device to "distort" the image (actually, to modulate the phase) is a sort of active LCD device developed by a group in Edinburgh. It is used to control laser tweezers.
Note: Sorry, I did not see the previous message. It showed up when I was still writing.
  • · Replies 24 ·
  • · Replies 22 ·
  • · Replies 19 ·
