Who Misinterpreted the Motion Equation, Me or My Teacher?
  • Thread starter Thread starter -Physician
    Teacher
The discussion centers on the correct interpretation of the motion equation s=vt under uniform acceleration. The original poster mistakenly equated s=vt with s=v0t+at^2, while the teacher correctly stated that the equation should be s=v0t+1/2at^2. The distinction is that s=vt applies only to constant velocity, not varying acceleration. To accurately describe motion under uniform acceleration, one must use average velocity, which is derived from the initial and final velocities. Ultimately, the teacher's explanation is validated, confirming the correct formula for motion in this context.
-Physician
Okay, so our teacher gave us to define s=vt. Now i did it like that:
s=vt=(v_0+at)t=v_0 t+at2, but then, teacher said that's wrong, it should give you s=v_0 t+ \frac{1}{2} at2 Who is wrong me or teacher, If I am wrong, tell me where is my mistake, if the teacher is wrong let me know, thanks!
I am assuming that this is a problem concerning the motion of a particle under uniform acceleration. In that case, the teacher is correct. The equation ## s = vt ## is only correct for constant velocity. If velocity is not constant, then you must replace ## v ## with the average velocity.
Under uniform acceleration, the average velocity is simply ##\frac{v_0+v_f}{2}##.
s=vt=(v0+at)t=v0t+at^2, but then, teacher said that's wrong, it should give you s=v0t+1/2at^2. Who is wrong me or teacher, If I am wrong, tell me where is my mistake, if the teacher is wrong let me know, thanks!
You are wrong.
Are you familiar with calculus? Derivatives and integrals? That's one way to derive those equations.
So that would be ##s=vt=\frac{v_0+v_f}{2}t=v_0 t + \frac{1}{2}##at2 or ##s=vt=\frac{v_0+v_f}{2}t=v_f t - \frac{1}{2}##at2
-Physician said:
So that would be ##s=vt=\frac{v_0+v_f}{2}t=v_0 t + \frac{1}{2}## at2 or ##s=vt=\frac{v_0+v_f}{2}t=v_f t - \frac{1}{2}## at2
Right?
Yes that is correct.
