Why Do Double Balanced Modulators Discard the Information Component?
Double balanced modulators discard the information component because they focus on the upper and lower sidebands, which carry the actual information. In contrast, single balanced modulators include the carrier along with the sidebands. The carrier does not contain any information, so it is suppressed in double balanced modulators to enhance performance and reduce distortion. This design allows for more efficient signal processing without the need for the carrier. Understanding this distinction is crucial for grasping the functionality of different types of modulators.
fran1942
Hello, we are learning about single balanced and double balanced modulators.
Apparently single balanced modulators include an information, upper and lower sideband component while double balanced modulators use only the upper and lower sideband components.
Can someone please tell me why the information component is discarded by double balanced modulators. How is that the information component is not necessary ?
Thanks for any help.
You have it backwards: information is carried in the sidebands, while the carrier, which contains no information, is suppressed in a double balanced mixer.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
