How Does Ampere's Law Calculate Current in a Uniform Magnetic Field?
The discussion focuses on using Ampere's Law to calculate the conventional current enclosed by a circular path in a uniform magnetic field. The magnetic field strength is given as 1.4e-06 T, and the radius of the path is 0.03 m. One participant consistently arrives at a current value of 3.19e4 A, which is questioned due to a significant discrepancy in magnitude. It is clarified that the vacuum permeability constant (μ0) should be used instead of the vacuum permittivity constant (ε0) in the calculations. The correct application of Ampere's Law is essential for accurate results in this scenario.
ineedhelp5454
Along a circular path the magnetic field is measured and is found to be uniform in magnitude and always tangent to the circular path.
If the radius of the path is 0.03 m and B along the path is 1.4e-06 T, use Ampere's law to calculate the magnitude of the conventional current enclosed by the path.
ampere's law -- integral(B*dl) = mu I
i keep getting 3.19e4 A
Hello ineedhelp5454,
Welcome to Physics Forums!
My answer is different by 5 or so orders of magnitude.
Show us your steps and maybe we can help figure out what's going on.
1.5e-6 * 2 * pi * .03 = 2.87e-7 (left half of ampere's equation)
2.87e-7 = 8.85e-12(mu) * I (right half)
I = 3.19e4
Is the magnitude of B 1.5 x 10-6 or 1.4 x 10-6 T?
I = 3.19e4
You're using the vacuum permittivity constant ε0 = 8.854 x 10-12 F/m, but you need to use the vacuum permeability constant μ0= 4π x 10-7 H/m.
They're not the same thing, but they are related. The speed of light in a vacuum c = 1/\sqrt{\epsilon_0\mu_0}
thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
