Ampere's Law For Static Magnetic Field
  • Context: Undergrad
  • Thread starter Thread starter BlackMelon
    Ampere's law Curl
The discussion centers on the application of Ampere's Law in the context of static magnetic fields, specifically examining the relationship between the magnetic field intensity (H) and current density (J) in a cylindrical wire carrying current. Participants explore the implications of the curl of H in both the interior and exterior of the wire.
  • One participant, BlackMelon, seeks to understand the equation Curl(H) = J, noting that the curl of the magnetic field intensity outside a current-carrying wire yields zero.
  • Another participant points out that the current density outside a wire is expected to be zero, which BlackMelon acknowledges as a realization.
  • BlackMelon later analyzes the magnetic field inside the wire and calculates the current density using Curl(H) = J, arriving at a specific expression for J.
  • A participant elaborates on the magnetostatic Maxwell equations, providing a detailed derivation of the magnetic field B and current density j for both inside and outside the wire, including integration steps and continuity conditions.
Participants generally agree on the mathematical framework and the expected behavior of the magnetic field and current density in different regions. However, there is no explicit consensus on the implications of the curl of H outside the wire, as initial confusion was expressed by BlackMelon.
The discussion includes assumptions about the cylindrical symmetry of the problem and the applicability of the magnetostatic Maxwell equations. Some mathematical steps and conditions for continuity are presented but remain unresolved in terms of broader implications.
BlackMelon
Hi there!
Please refer to the picture below. I would like to understand the equation Curl(H) = J, where H is the magnetic field intensity and J is the current density. So, I inspect a simple problem.
There is a wire carrying current I in the z-axis direction. a_r, a_phi, and a_z are the unit vectors in the directions of the radius, the tangential line, and z-axis, respectively.
So, from H = I/(2*pi*r)a_phi. I take the curl of this vector (in cylindrical coordinate) and got 0. How does this relate to the current density?
Best
BlackMelon
The field you've written down is the field outside a current carrying wire. What would you expect for the current density outside a wire?
Oh well it's zero. That was the silly of me LOL. Thank you very much.
By the way, I have analyzed the inside of the wire H = I*r/(2*pi*R^2) a_phi.
where r is the radius from the center of the wire to the point of interest. R is the radius of the wire. And got the correct answer:
J = curl (H) = I/(pi*R^2) a_z
Adding more information to my previous comment, here is how I calculate the current density inside the wire using curl(H) = J
The solution in local form is indeed given by using the magnetostatic Maxwell equations as follows:
$$\vec{\nabla} \cdot \vec{B}=0, \quad \vec{\nabla} \times \vec{B}=\mu_0 \vec{j}.$$
We have given
$$\vec{j}=\begin{cases}\frac{I}{\pi R^2} \vec{e}_z &\text{for} \quad \rho \leq R \\ 0 &\text{for} \quad \rho>R. \end{cases}$$
To solve this equations it's most simple to make the ansatz
$$\vec{B}=B(\rho) \vec{e}_{\varphi}.$$
Using the formula for the curl in cylinder coordinates you get
$$\vec{\nabla} \times \vec{B}=\frac{1}{\rho} \partial_{\rho} (\rho B) \vec{e}_z.$$
From this you get for ##\rho<R:##
$$\partial_{\rho} (\rho B)=\frac{\mu_0 I}{\pi R^2} \rho.$$
This can be immediately integrated to
$$B(\rho)=\frac{\mu_0 I}{2 \pi R^2}\rho + \frac{C}{\rho},$$
where ##C## is an integration constant. Since there's no singularity at ##\rho=0##, you get ##C=0##, i.e.,
$$B(\rho)=\frac{\mu_0 I}{2 \pi R^2}\rho \quad \text{for} \quad \rho<R.$$
For ##\rho \geq R## you have
$$\partial_{\rho} (\rho B)=0 \; \rightarrow \; B=\frac{B_0}{\rho} \quad \text{with} \quad B_0=\text{const}.$$
Now, at ##\rho=R##, ##B## must be continuous, which gives
$$B(\rho)=\frac{\mu_0 I}{2 \pi \rho} \quad \text{for} \quad \rho \geq R.$$
One should also check that ##\vec{\nabla} \cdot \vec{B}=0##, which however is already seen easily to be fufilled by the initial general ansatz.
We have given
Thank you very much for the explanation :)
  • · Replies 27 ·
  • · Replies 0 ·
