I When is Ampere's Law applicable in different scenarios?
Ampere's Law can be applied in various scenarios, but its effectiveness depends on the symmetry and constancy of the magnetic field. In the case of a solenoid, the law is straightforwardly applicable. For a hollow cuboid, using the same Amperian loop as the solenoid may not yield accurate results if the magnetic field is not uniform. If the magnetic fields around a loop are constant but unequal, applying Ampere's Law becomes problematic, as the law is most useful when the field is uniform. Ultimately, while Ampere's Law is always valid, its practical application relies heavily on the specific conditions of the magnetic field.
BlackMelon
Hi All,
In the attachment, I have 3 scenarios in question.
The first one is just a solenoid from http://hyperphysics.phy-astr.gsu.edu/.
The second one is a hollow cuboid, which is infinitely long. I am using the same analogy as the solenoid. Would I be able to set the same Amperian loop?
For the third one, I do not have the circuits. If the magnetic field of each side of the loop is constant, but all the fields are not equal, would I be able to apply the Ampere's law?
Edited: In the scenario 2, why applying both green and blue loop at the same time (which results in the magnetic field twice of that of the green loop alone) is wrong?
Best Regards
BlackMelon said:
Hi All,
Best Regards
What do you mean by "would I be able to apply the Ampere's law?". My flippant answer is that Ampere's Law is always true and can always be applied*. You can use any loop you choose. Which means that I'm not understanding your question.
*Within the limits of classical physics, of course.
Likes Gavran and davenn
Hi Dave
Please refer to the current loop in the following link:
http://bit.ly/3B5buxz
The Ampere's Law and the Biot Savart Law mismatch in this case. The reason is that the magnetic field along the Amperian loop is not constant.
Yet, we see from Hyperphysics site: bit.ly/4d7PAaj that if the mag field is constant at one side of the rectangular loop and zero at the other sides, we can apply the Ampere's law.
So, I am curious if the field of all sides are constant but not equal, would I be able to apply the Ampere's law.
As @DaveE said, Ampere's law is always valid and you can draw any loop you choose. Sometimes the symmetry of the problem is such that you can draw the loop in a way that makes it easy to solve the problem. But in most cases you draw the loop and you don't know how the magnetic field varies spatially, so Ampere's law really isn't much help.
Likes DaveE and davenn
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
