What does 0 amplitude mean in waves and quantum physics?
  • Thread starter Thread starter MathewsMD
    Amplitude Waves
MathewsMD
When a wave for light or an electron is represented on a graph, it is shown with the y-axis representing amplitude. Now, these waves cross the x-axis (where amplitude=0) but what does this actually mean, for that instant? Is it that the wave is no longer observed for that instant?
Also, since all objects have their own wavefunctions, what does the concept of 0 amplitude mean? Is the object not observed for that one instant as well?
I'm new to the concept of the wave properties of matter and quantum physics as a whole, so any clarification on the above matters (and other related material, if you wish) would be greatly appreciated!
The modulus squared of the wave function is the probability (density) to find the particle at a point (region) in a position measurement. If the amplitude is zero, you won't find the particle at this point (region).
Okay. So since all objects have a wavefunction, what exactly does it mean for the object (ex. couch) to have a 0 probability?
Does it cease to exist at some infinitesimal point that we just never see?
Before you perform a measurement, quantum systems don't have a definite value for the physical quantity you measure. If the wave function is zero in some region, the particle is not in this region. But you can't say where it is with certainty. The probability to find it in a region with a large amplitude is simply higher than in a region with a low amplitude. So it is very unlikely to find the particle in the region where it's wave function has a node.
I think the obvious is being overlooked - just because a wave occupies a zero value at some point in time (or space) does not mean the amplitude is zero at that time (space).
Amplitude is the magnitude of a complex number. The value of the field is the projection of the complex number onto the real axis.
Claude.
Nevertheless it does mean that the probability of locating a particle at that point, or probability of "particle" manifesting itself into a particle if measured at that point, is zero. Isn't it?
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
