An exponential problem and a trig problem
  • Thread starter Thread starter Kb1jij
    Exponential Trig
The discussion revolves around two challenging math problems encountered in a competition. The first problem involves the equation 9^x + 9^-x = 34, where participants suggest substituting 9 with 3^2 to simplify the expression and factor it effectively. The second problem requires finding the exact value of cot 15 + cot 75, with users discussing the application of sum and difference formulas for cotangent to simplify the calculations. Ultimately, the second problem is solved to yield a result of 4, demonstrating the effectiveness of using integral approaches and sum formulas. The conversation highlights the complexity of competition-level math and the collaborative effort to find solutions.
Kb1jij
Yesterday in a math competition, I came across two problems that I couldn't (and still can't) figure out how to solve under the competion conditions (in under three minutes, without using a calculator).
The first one involved expential functions. When I try to do it I just get a huge mess of exponents and logs that takes me forever to simplify. It is as follows:
9^x + 9^-x = 34, evaluate 3^x+3^-x
The second problem involved trig functions:
Find the exact value of cot 15 + cot 75
Are there sum and difference formulas for cot? I tried turning the cot into cos/sin and then adding the fractions. That left me with
\frac{\sin(15)\cos(75)+\cos(15)\sin(75)}{\sin(75)\sin(15)}
Using the sum formula this would become
\frac{\sin 90}{\sin(75)\sin(15)} = \frac{1}{\sin(75)\sin(15)}
Can I do anything with this?
Thanks for your help!
Tom
for the first problem, notice that 9^x=3^(2x) since 9=3^2, so substitute that in, then factor.
for the second problem 75= 60+15, and 15=30-15. now you can use the sum formulas for the denominator. i didn't do it out, but i'd try that.
Another approach for the second problem is to see that
15 = 45 - 30 and that 75 = 45 + 30
Ok, I got the second one, it's 4. I was avoiding using the sum formulas because I thought that I would just get a large mess of sines and cosines, but if you use integral's approach, the sums up being the difference of two squares, and it isn't really that complicated.
How can I factor 3^(2x)+3^(-2x)?
yeah, integral's was a better way for using the sums, was a bit simpler, same idea. it does work the way i explained too.
for the factoring, isn't there a 3^2 in both those terms? after that, its very simple.
I don't understand how I can factor a 3^2 out.
3^2(3^x+3^-x) is equal to (3^x)(3^2)+(3^-x)(3^2) or 3^(x+2)+3^(-x+2).
Also, 3^(2x)/3^2 would just become 3^(2x-2).
sorry. you're right, you can take out the two though. here:
(3^x + 3^-x)^2 = 3^2x + 3^-2x +2(3^x)(3^-x)= 3^2x + 3^-2x +2(3^0)
so
3^2x + 3^-2x = (3^x + 3^-x)^2 - 2 = 34
now it works out nicely eh?
Wow, great. That does work out very nicely. That is a pretty tricky problem, but that's what I would expect from this competition.
Thanks!
Tom
