An interesting inequality-question on the proof
  • Thread starter Thread starter jeffreydk
    Interesting Proof
jeffreydk
An interesting inequality--question on the proof...
I am working on the following proof and have gotten about half way;
If a_1, a_2, \ldots , a_n are positive real numbers then
\sqrt[n]{a_1 \cdots a_n} \leq \frac{a_1+a_2+\ldots +a_n}{n}
By induction, I started by showing it for n=2, which goes as follows.
We must show that \sqrt{a_1 a_2} \leq \frac{a_1+a_2}{2}. So consider some s, a positive real number. If
\sqrt{a_1 a_2} \leq s \Rightarrow \sqrt{a_1 a_2} \leq \frac{\sqrt{a_1a_2}+s}{2} \leq s
And since \sqrt{a_1a_2}<a_1+a_2-\sqrt{a_1a_2}, just let that equal s. Then it follows that,
\sqrt{a_1a_2} \leq \frac{\sqrt{a_1a_2}+a_1+a_2-\sqrt{a_1a_2}}{2}
Where after simplification we have shown that \sqrt{a_1 a_2} \leq \frac{a_1+a_2}{2} or in other words it is true for n=2.
Now for the next part of the proof, I think we must show that if it is true for n=2^m then it is also true for n=2^{m+1}. And then we must also show it if 2^m < n < 2^{m+1}, but this is where I am stumped. Sorry for the choppiness in my explanation. Thanks for any assistance, I appreciate it.
Eh, well the n = 2 case could be proved in an easier way just be multiplying both side by 2, squaring, rearranging, and factoring. It follows from the trivial inequality x^2 \geq 0
As for the induction, I'm not sure why you use n = 2^m since it works for any natural number n. Anyways AM-GM is not easy to prove by induction since you have to apply an algorithm that is also used in a proof without induction.
Actually, one of the classical proofs of the AM-GM inequality is an inductive one. The proof is due to Cauchy, and it follows the main ideas in the OP, i.e. inducting on powers of 2.
There was a thread on this sometime back, here is the link. Check it out and post back if you need further help.
Oh alright, I didn't realize this was such a famous proof (Cauchy). Thanks for alerting me to that reference.
It can also be derived from the inequality
\exp(x)\geq 1+x (1)
This is trivial to prove. It follows from this that:
\left\langle\exp(X)\right\rangle = \exp\left(\left\langle X\right \rangle\right)\left\langle\exp\left(X - \left\langle X\right \rangle\right)\right\rangle
Apply (1) to the last factor:
\left\langle\exp\left(X - \left\langle X\right \rangle\right)\right\rangle\geq \left\langle 1 + X - \left\langle X\right \rangle\right\rangle = 1
So, we have:
\left\langle\exp(X)\right\rangle \geq \exp\left(\left\langle X\right \rangle\right) (2)
This is a special case of the convex inequality and the AM-GM inequality is a straightforward consequence of that inequality. But the convex inequality requires a bit more work to prove. The AM-GM inequality follows from (2) by taking X to be the logarithms of the a_i. The average on the l.h.s. is then the arithmetic mean, while on the r.h.s. you get the geometric mean.
