Analysis of a wind vane/weather vane
  • Thread starter Thread starter james6008
    Analysis Wind
The discussion focuses on modeling the motion of a weather vane in response to changing wind directions. Participants explore the forces acting on the vane, the calculation of turning moments, and the incorporation of mass into the model.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant describes a model that simulates the weather vane's motion based on wind direction, using a force equation to calculate the force acting on the vane.
  • The same participant seeks guidance on incorporating the mass of the object into their model and is uncertain about the appropriate equations to use.
  • Another participant provides a link to a resource on the moment of inertia, suggesting it may be relevant to the discussion.
  • A subsequent reply indicates that the participant has previously reviewed the moment of inertia but is confused about how to integrate it with the force calculations already being performed.
  • Another participant requests detailed calculations related to the wind vane model.
  • A final post suggests using software tools like Hypermesh or Gambit for modeling and finite element analysis to calculate the behavior of the weather vane.
Participants express varying levels of understanding regarding the mathematical relationships involved in modeling the weather vane. There is no consensus on how to effectively incorporate mass into the existing model, and the discussion remains unresolved.
Participants have not fully clarified the assumptions underlying their calculations, and there are unresolved steps in linking the force and moment of inertia equations.
Individuals interested in modeling physical systems, particularly in the context of fluid dynamics and mechanical systems, may find this discussion relevant.
james6008
Hi
I am trying to create a model to simulate the motion of a weather vane. It basically looks at the wind direction and as the wind direction changes, the objects responds by trying to align itself parallel to the wind.
First of all I am looking at the force perpendicular to the pivot point of the vane. This force increases as there is a greater change in the wind direction.
I am using F= 0.5*rho*(v^2)*A to calculate the force
where v = velocity (wind speed) and A=area of the vane
I am using this force and resolving it for an angle (theta) which is the change of wind direction. I am then calculating the turning moment of the object by using this resolved force and the distance from the pivot point. This turning moment governs the respond of the object to the change in the wind direction.
I am stuck right now because I need to try and incorporate the mass of the object in this model. I am not sure where is the right place to include this and what equation do I need to use?
Can you please help/guide me in the right direction?
Thank you
Hi
Thanks for this. I've had a look at this before but I got lost in the maths.
I am already calculating the Moment which is Force*distance from the pivot
The Moment of inertia is just mass m * square of its perpendicular distance r
How will I link both the first equation and second one? Because I want it to consider the force that has been applied to move the weather vane in the direction of the wind against the actual mass of the body.
please tel me the detailed calculation of wind vane...please post it soon ...
You may create a model and its mesh with Hypermesh or Gambit, then import the mesh to the Fluent unsing the finite element method to calculate.
  • · Replies 40 ·
  • · Replies 16 ·
