Solving Analytic Functions Homework: Find f(z) = u(x,y)+iv(x,y)
  • Thread starter dan280291
  • Tags
    Functions
In summary, the conversation discusses using Cauchy-Riemann relations to find a function u given v(x,y). The user is unsure of how to integrate the fractions partially and asks for clarification. The solution involves finding both partial derivatives and using substitution to integrate 2yx/(x^2 + y^2) with respect to x.
dan280291
Given v(x,y) find [itex]f(z) = u(x,y) +iv(x,y)[/itex]
v(x,y) = 3y -2(x^2 - y^2) +(x) / (x^2 + y^2)
Using Cauchy Riemann relations I've found
[itex]dv/dx = -4x + (x^2+y^2)-1) +2x^2(x^2+y^2)-2 = -du/dx[/itex]
Now integrate that with respect to y to find u
But I'm not too sure how to integrate the fractions partially.
Also I've found [itex]dv/dy = 3 +4y -2yx/(x^2 + y^2)[/itex]
Where is the problem? You have to find a function u, that, when you calculate the derivative with respect to x, has to have some specific form, and for the derivative with respect to y you get another known expression (check your relation(s)).
To find u, you can use an integration with respect to x or y, respectively.
Hi thanks for the reply. Does that mean you only have to find dv/dy and integrate with respect to x? You don't need to use dv/dx?
Also as for the integration how is 2yx/(x^2 + y^2) integrated with respect to x?
Thanks again.
Thanks again.
You need both ##\partial u/\partial x = \partial v/ \partial y## and ##\partial u/ \partial y = - \partial v / \partial x##.
Thanks for the help off everyone. Last thing could anyone tell me how 2yx/(x^2 + y^2) is integrated with respect to x?
Hint: look at the derivative of the denominator. Do you see some nice substitution?
Related to Solving Analytic Functions Homework: Find f(z) = u(x,y)+iv(x,y)
1. What is an analytic function?
An analytic function is a complex-valued function that is differentiable at every point within its domain. This means that the function has a well-defined derivative at every point, and the derivative can be calculated using the limit definition.
2. How do you find the real and imaginary parts of an analytic function?
To find the real and imaginary parts of an analytic function, we can use the Cauchy-Riemann equations. These equations relate the partial derivatives of the function with respect to x and y to the real and imaginary parts of the function. By solving these equations simultaneously, we can find the real and imaginary parts of the function.
3. What is the purpose of finding the real and imaginary parts of an analytic function?
By finding the real and imaginary parts of an analytic function, we can better understand the behavior of the function. This can help us visualize the function and make predictions about its behavior. Additionally, finding the real and imaginary parts is necessary for solving many complex analysis problems.
4. How do you find the derivative of an analytic function?
The derivative of an analytic function can be found using the Cauchy-Riemann equations or by using the limit definition of the derivative. By computing the derivative, we can find the slope of the function at any point and determine whether the function is increasing or decreasing at that point.
5. What are some common applications of analytic functions?
Analytic functions have many applications in mathematics and physics. They are used to model physical phenomena such as fluid flow, electromagnetism, and heat transfer. They are also used in engineering and computer science for signal processing, image processing, and data analysis. Additionally, analytic functions are essential in complex analysis, which has applications in many areas of science and engineering.
