Analyze this circuit with 2 sources and 4 resistors
The discussion revolves around analyzing a circuit with two sources and four resistors, focusing on current flow and the implications of a dependent voltage source labeled "5i." Participants emphasize the need to set up a system of equations using Kirchhoff's Current Law (KCL) and Ohm's Law to determine the actual current paths and voltages at various nodes. The circuit's configuration, particularly the relationship between the 2-ohm and 6-ohm resistors, is debated, with suggestions that the 6-ohm resistor has negligible impact on the overall analysis. The importance of understanding supernodes and the correct application of KCL is highlighted as essential for solving the circuit effectively. The conversation underscores the necessity for participants to demonstrate their analytical efforts to receive further guidance.
mkamalzayed
New user has been reminded to show more effort on their schoolwork threads at PF
Find v1,v2,v3 using nodal analysis
"I in" ="I out" (KCL)
How does the current flow in this circuit and what is its actual true path, regardless of any directions in the figure?
What does the “5i” above the dependent source mean, and does the current flow according to the dependent source or the independent source?
Are the two resistors 2 ohms and 6 ohms connected in series or parallel?
I want to know more and more from the Veterans in electricity
Hi, :welcome:
That is asking for the final answer. You'll have to carry out the analysis to find it :wink:. I.e. set up a system of N equations with N unknowns and solve.
The diamond
represents a dependent voltage source of ##5i## Volts, where ##i## is the current through the ##2\Omega## resistor (
in the diagram). Be sure to use the correct sign.
Likes scottdave
Thread closed for Moderation...
Thread is reopened provisionally.
@mkamalzayed -- You are required to show more effort before we can offer tutorial help. Please show us your attempt at setting up the KCL equations, and begin to solve them. I will send you a Personal Message (PM) with some tips for how to use LaTeX to post math equations at PF.
Likes BvU
User is reminded *again* to show their work on the problem so that we can help them
BvU said:
Hi, :welcome:
The diamond View attachment 353099 represents a dependent voltage source of ##5i## Volts, where ##i## is the current through the ##2\Omega## resistor (View attachment 353100 in the diagram). Be sure to use the correct sign.
Explain more and more
Sigh. Thread is closed again for a bit...
I'm in a PM conversation with the OP at the moment; I'll try to get them to show some effort so we can reopen the thread.
Likes phinds
Okay, whew. OP has shown me their work on the problem, so I'll reopen the thread (still provisionally) so they can upload it. I am working with them to help them learn LaTeX, but for the moment they will upload a picture of their hand-written work. (the quality is not too bad, just a little dark)
I don't the final answer
I want to understand the figure and how the current flows and from any source ???? and I want to understand everything about this figure
mkamalzayed said:
Homework Statement: Find v1,v2,v3 using nodal analysis
Relevant Equations: "I in" ="I out" (KCL)
I want to know more and more from the Veterans in electricity View attachment 353084
Please upload the picture of your work so others can see what you have done. Thanks.
Go ahead
Can you check your statements
Perhaps it is useful to explicitly declare the three (!) currents at each node.
And 'node 2 has a dependent voltage source' makes no sense!
It's all pretty basic: you have defined three nodes. At each node KCL says ##\sum i=0##.
If you followed my advice
you have something like the following diagram in front of you:
[edit] the current entering node 3 is named i5, not i4. Updated the image.
No worries about the directions of the currents: the correct sign will come out in the analysis.
The KCL for the three nodes give you three equations, Ohm's law four and the two sources two. Nine equations in nine unknowns. Straightforward math to find e.g. ##v_2## first, then ##v_1## and ##v_3##.
If you still need 'more and more', you'll first have to clearly summarize what you know already and what it is that inhibits you from dealing with this exercise.
Likes DaveE
In order to get a unique solution, the equations must be independent. The nine you propose are not independent.
Besides which the TS seems to be gone away.
  • Skeptical
Likes DaveE
Maybe you meant sufficient instead of independent?
Which implies some KVL equations. Let's say a solution is defined by finding the 6 currents, then you only need 6 independent equations. These could be 3 KCL nodes and 3 KVL loops, with Ohm's law to connect them. I bet I could solve this with @BvU 's prescription. Except for the problem of being too busy, too lazy, and not really excited by the solution, whatever it is.
The two equations for the sources are ##v_1=v_2+25## V and ##v_3=v_2+5i## V.
In other words, i5 is not indpendent of i. Likewise, v2 is not independent of v1. These are constraint equations.
Since a network with 3 nodes like this would need at most 3 equations to solve it, given more than 3 equations they are not all independent.
This network needs only one KCL equation and two constraint equations. The 3 nodes can be treated as one supernode.
Note that the 6 ohm resistor does nothing. It can have any value, or it can be missing.
Also note that the problem statement requires a nodal solution.
Likes DaveE and BvU
Checking...
[edit]Aren't we having fun ? Disagreements appear to come from communication issues. Where I think in terms of degrees of freedom and consider something like ##\ v_1-v_2=25\ ## an equation, someone else calls it a constraint.
I agree the answers to 'Find v1,v2,v3 using nodal analysis' is independent of the value of the resistance in the top branch. But I would select a different wire gauge for the top loop if the resistance would be 0.1 Ohm instead of 6. I didn't dig into the supernode issue but instead wanted to help the OP to set up reasonable KCL equations instead of what came up in #12.
Likes SammyS
Yes, it's a good observation. The zero impedance branches can effectively cut the network in two. Of course i6 does effect i4 and i5, but nothing else. So superposition let's you solve the lower loops separately, with 2 nodes and two loops.
KVL #1) ## 4i_2 - 2i + 25 = 0 ##
KVL #2) ## 3i_3 - 4i_2 +5i = 0 ##
KCL #1) ## i + i_2 + i_3 = 0 ##
Likes BvU
I do feel a bit o:) from taking over the OP choice of nodes at ##v_1, v_2, v_3## instead of using the one at the bottom :smile:
How ?? "5i" is a current not a voltage
I find that the directions of these currents are strange and illogical
On what basis did you do it?
Explain that to me in detail
What is the actual, real, original path that the current is taking?
Depending on your assumptions
Node v2 does not receive any current
How do I apply the KCL law?
What path directions did you take to apply KVL?
Tell me more
Tell me more
Have learned about the concept of a "supernode"?
As I said in post #19: This network needs only one KCL equation and two constraint equations. The 3 nodes can be treated as one supernode.
Explain that to me visually
  • #31
v2 receives i2, i4, i5.
  • #33
mkamalzayed said:
Where????
These currents flows out of v2
Look at the diagram in post #15. i2, i4 and i5 are shown.
  • #34
i2,i4,i5 flows from v2
There are not currents entering the node v2
  • #35
You are forgetting what BvU said in post #15: "No worries about the directions of the currents: the correct sign will come out in the analysis."
The arrows on the diagram may not be showing the direction of physical current flow. What if i2 has a negative value?
  • #36
Proceed like this. First note that the 6 ohm resistor is connected across voltage sources so it has no effect on the values of v1, v2 and v3; remove it--that means i6=0.
Treating v1, v2 and v3 as a supernode means that you don't write 3 KCL equations for each of v1, v2 and v3. Instead you write one KCL equation for the supernode (the supernode being the combination of v1, v2 and v3). That equation expresses the fact that the sum of the currents entering or leaving the supernode sum to zero.
If i6=0, then i=i4 and i3=i5 so the 3 currents i, i2 and i3 are the only currents entering or leaving the supernode. So we have i+i2+i3=0. Can you express that equation using v1,v2,v3 and the values of the 3 resistors?
To finish you'll need two constraint eqations; I'll help you with those.
  • #37
BvU said:
The diamond
represents a dependent voltage source of 5i Volts, where i is the current through the 2Ω resistor (
in the diagram).
You have chosen not to answer any of the questions asked in #14, so why should I bother to answer
Before diving into supernodes, you should first come to understand the diagram and why KCL says ##\ \ i_2+i_4+i_5=0\ \ ## (or ##-i_2-i_4-i_5=0##, which is equivalent).
Likes SammyS
  • #38
The OP is on a 10-day vacation from PF for several issues, so I'll go ahead and close this thread for now. It may be reopened after the OP is back if they send me a PM and show me what they understand about this circuit analysis. Thank you to all who have been patiently trying to help this user in this thread.
