Analyzing Trapeze Movement: The Role of Gravity and Energy Loss
  • Thread starter Thread starter katkinson
    Movement
Trapeze movement is influenced by gravitational forces and energy loss primarily due to air resistance. As the trapeze swings, potential energy converts to kinetic energy, but energy is lost to air resistance, which slows the motion. On the moon, the lack of atmosphere would reduce air resistance, but internal friction in the supporting mechanisms would still cause some energy loss. The vertical component of centripetal force and gravity plays a significant role in the trapeze's stopping motion. Understanding these dynamics is crucial for analyzing trapeze performance in different gravitational environments.
katkinson
Essentially, we are writing a report on the movement of a trapeze but I am very stuck. My main questions are:
why do trapeze slow down?
What effect does gravity have on the trapeze?
My personal research question is what were to happen if the trapeze were on the moon rather than earth, would it still work?
Here is what i know so far:
Clearly, while standing on the board, I had 100% PE (mgh)
Then at the bottom of the swing, when I was closest to the ground, I had 100% KE (1/2 mgv^2)
Also, I know that centripetal force= mv^2/r
Right now, I think that you lose energy while on the flying trapeze due to air resistance "taking" that energy from you. However, to determine what would happen on the moon, I need to understand what happens on earth. Drawing free body diagrams, I believe that the trapeze motion stopping has something to do with the vertical component of Centripetal force (or the slanted component of gravity).
I am sorry if this does not meet the regulations, I honestly tried to do so, but I am quite stuck. Either way, thanks for the help and taking the time to read through my questions
Even without an atmosphere there would still be some internal friction in the rope, wire, or chain supporting the trapeze and at the pivot point, but the energy lost (converted to heat) would be small.
Thanks for the response. What else slows the trapeze then? What makes the trapeze stop (on each swing)---gravity?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
